I need some help choosing a cutting fluid for turning and milling.
When I use cutting fluid, I apply small amounts via a plastic drip bottle (my lubricating needs are for aluminum, cold rolled steel and drill rod/tool steel) and used primarily to lubricate. I have been using TapMagic with much satisfaction but have noticed as many others on the board have commented: if cuts are aggressive enough to cause smoking, the TapMagic causes machine discoloration (unless sessions are followed by exhaustive wipe downs with oily rags).
Can anyone recommend a good cutting fluid which will not stain my work or tools? I tried some Trico synthetic Microdrop lubricant from a small sample I have, and it seems to work very well, but the price knocked my socks off at $71/gallon.
(I also have an unused 15 year old MicroDrop unit, but it never seems to be worth while hooking it up, as the plastic drip bottle seems to serve my needs. Although I usually agree that the more tools the better, my innate feelings about cutting fluids is the less the better….I hate cleaning up, rust and discolored tools!)
I've searched the archive, but couldn't come up with a good consensus.
Mike
Mike
