Converting in/ft taper into degree taper
Results 1 to 12 of 12
    Dec 2004
    Raleigh NC
    38
    Smile Converting in/ft taper into degree taper
    I have to make several tapered spacers, one with a 2.364 in/ft taper, and the other with a 2.691 in/ft taper. As I do not have a taper attachement, and the holes are only 1" deep, so I plan to use a boring bar in the compound slide. As this is graduated in degrees, I need to convert inch/foot taper measurements to included angle taper measurements.
    I googled for a conversion formula, but was unsuccessful. Can anyone assist?
    Paul
    Apr 2002
    Covington, Wa
    903
    30
    93
    You need Machinery's Handbook
    Taper(inches per foot) = 24tan(half angle of taper)
    Jul 2004
    Spartanburg, South Carolina
    1,531
    47
    91
    You might benefit from a visual approach to solving your problem (and learn a little trig in the process )
    Freebie:
    http://wildone296.home.mchsi.com/kwiktrig.htm
    Determine whether your angle is taper per side or taper of the included angle.
    Feb 2005
    Ann Arbor, Michigan USA
    1,336
    Fundamentally you have a right triangle problem to solve.
    Let the length be the base and the adjacent side to the angle of interest of a right triangle, that is 1 ft or 12 inches. The opposite side of the right triangle is 1/2 of the diameter change or 2.364/2 = 1.182.
    The tangent of an angle B is the ratio of the opposite to adjacent sides. Thus, 1.182/12 = tan B . There is another term called the arctan and this is the inverse of tan. So B = arctan 0.0985 . Using a calculator, or tables you can determine the angle.
    From my HP 32S I get 5.63 deg. This is 1/2 half of the included angle of your taper. I believe your compound will be calibrated in degrees of its rotation and not in included angle. Thus, set your compound to 5.63 deg. It might be calibrated such that you need to use 90 - 5.63 .
    Double check my calculations.
    Oct 2007
    Michigan
    95
    Taper is .017 per inch for 1 degree. Mach handbook lists constants for 5" sine bar. 1 deg is 0.08725. divide by 5 = .01745. Hope this helps. In the shop we just use .017 for most everything except the nitty gritty. This is taper per side.
    Jul 2004
    Houston, TX USA
    27,201
    And the other one is 90 - 6.398
    Oct 2007
    Connecticut
    31
    Oct 2006
    Mayretta, Ga.
    125
    Default Half way there
    Now, how are you going to set the compound to the desired two decimal accuracy? Some call me Carlos.
    Nov 2006
    Houston, TX.
    447
    49
    25
    Now we go back to not needing the trig, mount a dial indicator on the bed and tram the side of the cross slide until you have it set to .394 in per 2" of saddle movement (.4485 for the second taper). Or what ever ratio of the specified slope you have room to use.
    May 2002
    South Central PA
    12,499
    1551
    2659
    +1 for Shimitup. When I have to set an angle specified in degrees closely, I have to trig it the other way in order to set the compound accurately. With your in/ft spec, it's already done for you.
  11. #11
    Nov 2005
    Maryland
    8,502
    741
    1055
    Quote Originally Posted by partoff123 View Post
    With a sine bar, like any other precision setup. It's laid on its side as in the following illustration (top view, drawn at 7º):
    The tricks here are setting a reference plane on the compound parallel to its axis of movement, and holding the sine bar and gage blocks in position on its side. This would be simpler with an angle standard. Variants of the configuration are obvious.
    Rotate the compound to set the angle, and move the carriage to check the setting over the length of the sine bar. Tool movement for the cut uses the compound screw, obviously.
    The achievable accuracy is limited by the characteristics and condition of the machine, not by the measurement technique.
    - Leigh
  12. #12
    Mar 2005
    Northumberland England
    317
    5
    7
    Take the small dia from the large dia, divide by the length, look up the answer in the tan tables that gives you degrees. Half the answer, that is the setting of the top slide in degrees. If your cutting tool is not at center height it will alter the taper
    MBB
