JohnnyJohnsoninWI
Hot Rolled
- Dec 9, 2003
- North Freedom, WI, USA
My wife and I want to finish our basement this summer. One of the obstacles we must negotiate are the load bearing posts, which support the main beam, which, in turn, support the floor joists. We'd like to keep the basement fairly open with larger rooms, without having any support posts in the middle of the room.
Our house is 11 years old. The basement walls are poured concrete, the floor joists are 2X10's on 16" centers and span 25 feet across the width of basement.
There is a beam which runs the length of the basement and supports the floor joists. The beam is slightly off center (13'4" vs 11'4" from the walls). This beam is made of (engineered?) wood and looks like two 2X10's laminated together, except they are actually 1 3/4 x 9 1/2" and don't look like natural lumber. Total beam dimension is 3 1/2 x 9 1/2".
This beam is supported by 3" diameter steel posts that are screw adjustable for height. The posts are spaced every 93 to 98 inches apart, except for the end posts which are about 6' from the wall. I'm told each one of these posts sits upon a concrete "footing" and are not to be moved.
My questions are; can I remove a couple support posts. The posts I'd like to remove are not located consecutively and would result in unsupported spans of 14 and 16 feet.
What's the maximum span that my floor beam can support? Is it possible to increase the safe load bearing spans by adding (laminating) another 2x10 onto the main beam? There is room to do this and the pads on top of the posts are wide enough to support an extra 2x10. I could even add a large steel channel instead of lumber, if so advised.
As you can tell from my inadequate building terminology, I'm not a carpenter or an architect. We have a contractor coming over this Friday, however, we'd like a second opinion ahead of time. Any opinions, suggestions, or links are appreciated.
John
John
