Results 1 to 4 of 4
    greif is offline Junior Member
    Jul 2006
    kaukauna, WI
    Post
    Hi
    I am looking for a deburring cutter for deburring the back side of a hole.
    I remember see adds for 1 type, it had a shank and then it had a half spere with flutes cut on the half spere that is just for doing this type.
    would anyone know of the tool/ maker I am taking about?
    thanks
    greif
    mosheenist1 is offline Plastic
    Jul 2006
    Oklahoma
    8
    Post
    I have used a tool called a Cogsdill chamfering tool on the inside of some "UN-burrable" holes that worked WELL. It has a spring loaded blade that passes thru the hole, and the blade pops out to chamfer "deburr" the back side of the hole.
    gar
    gar is offline Stainless
    Feb 2005
    Ann Arbor, Michigan USA
    1,336
    Post
    060726-1009 EST USA
    greif:
    J&L Vol 75 p 394W
    www.jlindustrial.com
    Search for Deburr Master .
    Acumen is offline Aluminum
    May 2006
    RI
    152
    Post
    I use a tool from Heule called COFA. They are fairly expensive, but the blades last a long time. If you decide to get one of these, I can provide you with the G code to deburr both sides fast...
