Do propane forklifts run crappy in cold weather ?
Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    D. Thomas Guest
    Yesterday was amazingly cold and windy here, esp considering today is back to 64 degree Spring like conditions. Anyway, my Toyota lift started running terribly yesterday (outside), but today is running fine again. Was it the mid 30's temps or just coincindence ?
    Jun 2003
    climax,ga. 39834
    2,246
    6
    I had a large propane powered fork lift way back in the early 70's.It would sometimes act up in cold weather.Hyster service man traced it to condensation freezing up the regulator.Solution: warm the regulator with my wife's hair dryer.The hand held type.Worked every time!
    Mar 2003
    Huntsville, AL U.S.A.
    1,166
    17
    64
    Also check the engine coolant level.
    If the coolant is low, it will not warm the vaporizer properly. And liquid propane doesn't burn good. Something about them lumps.
    Ray
    Mar 2003
    1,166
    17
    64
    I know how those double post happen.
    I clicked "Send Now", and the response was document blank.
    I could see text so I clicked "Send Now" again. When I was redirected back I had a double post.
    So I edited it to explain what happened.
    Ray
    [This message has been edited by timekiller (edited 02-28-2004).]
    Mar 2002
    ontario,canada
    168
    my propane truck wont even start in winter!
    [stored outside]
    scottie
    Harold Hunt Guest
    Yep, check the rad level, also check the heater hoses going to the vaporizer. When the engine is fully warmed up both of the hoses should feel the same temp. If one is cold there is a restriction.
    Also make sure the thermostat is in place and operating. A stuck open stat will keep the engine cold and freeze up the vaporizer.
    Is this forklift running a real fork lift tank ( liquid draw ) or a gas grill tank ( vapor draw)? A vapor draw will work if the temps are warm and / or the load is low.
    My old Cat 422S runs in 20* weather without a problem. I did freeze the vaoprizer when I was flushing the coling system on a cold day. Too much cold water and no time to heat up.
    Your truck might just be in need of a tune up and the cold weather made it more noticeable.
    Harold
    Aug 2002
    West Unity, Ohio
    23,099
    3402
    6390
    I've never had a problem with it, but early this winter I was down near Indianapolis (I think?) picking up a Davenport parts machine for a bud, and the guy loading it had to keep one hand down in the motor comp and squeezing the intake hose to keep it running. Like a choke I guess? LOL!
    Timekiller:
    There is a much easier method to dbl posting... Alls you have to do - is once your new thread loads, just hit "back" to go back to the front page. Never fails on this site for me at all. LOL! I have to try to remember where I am at when I'm here b/c this is diff than I am used to. LOL!
    Think Snow Eh!
    Ox
    Feb 2004
    Burlington Wa
    67
    A friend who works on Liftrucks for a living asvises me to change the spark plugs for any running problem even if they seem to look ok. He further advises me to run a very rich mix of antifreeze as the vaporizer will freeze from the expansion of the fuel.
    Mar 2003
    NE Iowa, USA
    80
    5
    Don,
    I am not sure about now, but 30 years ago, you did not really buy propane in the South. It was actually butane. RV's that had their 20# tanks filled in the South and came back north before the end of the winter, had to have the valves removed and the butane poured out and the tanks refilled with propane to get through the winter.
    Butane is cheaper than propane, but won't volatilize at as low of a temperature as propane. -- mm
    Jan 2004
    Williams Lake, BC, Canada
    2,892
    5
    Try to start a propane vehicle at -50! Lots of boiling water poured over the heat exchanger, build a small fire under the oil pan, more water. It stays liquid at that temp.
  11. #11
    Jim Harris Guest
    Don - In shopping with a friend for a scissors lift about a year ago we decided engine powered was better for our needs than battery type. All of the ones we looked at were dual-fuel--propane + gasoline. I asked why and the man said "so you can run it outdoors in the winter". Apparently propane can be a PITA in cold weather unless the vehicle is especially equipped for it.
  12. #12
    Feb 2004
    Kiron IA USA
    408
    7
    I put together a propane fired forklift and below about 20, it doesn't seem to want to fire. Like on a gas engine if the choke isn't completely shut. But it seems to flood too. Once it is running it is fine.
    I would like someone to give me a short lesson on posting pictures here. I would like to put a picture of it here but can't figure out how. I made several pieces for the forklift with my old lathe that is worth more as scrap iron than a machine tool.
  13. #13
    Aug 2004
    Toronto, Ontario
    17
    Have run Chrysler (318's) trucks on propane for the last 20 years and never had a problem. Temp. here rarely goes below -25 deg. F. and I always run a 50/50 antifreeze mixture, be sure to keep the level up as the vaporizer will frreze easily even in summer heat. In fact those engines run the smoothest when the weather is cold and they are unmodified in any way.
  14. #14
    Aug 2002
    West Unity, Ohio
    23,099
    3402
    6390
    For pics - you need to first find a host site as Davey doesn't have pic hosting. What a tightwad! LOL!
    Think Snow Eh!
    Ox
  15. #15
    Mar 2003
    North Wales GB
    2,384
    The ignition system for lpg (LIQUIFIED PROPANE GAS) has to be spot on.
    You see,the gas is an insulator and it is very hard for the spark to jump the gap at the plug.
    if your mixtures too rich it will insulate even more....see tuning notes below
    plugs have to be changed every or before 8000 miles......also the dizzy cap has to be spot-on and also the ht leads.
    it is also recomended that you reduce the sparkplug gap by about 20%
    tuning ...pinched from
    uk.rec.cars.fuel.lpg
    I tune mine by ear. Probably not quite as spot-on accurate as it would
    be with a meter, but good enough for me (and the emissions test).
    With the engine fully warmed up and at idle, twiddle about with the
    'mixture' screw on the vapouriser - slowly unscrew it to enrich the
    mixture until it begins to run lumpily. Now screw it the other way to
    weaken it until the engine starts to lose revs and run unevenly. Don't
    rush it, as it may take a few seconds for the engine to respond and
    settle down to your adjustments - take your time and find these two
    spots carefully. Aim to set it midway between the two. It's much like
    setting the mixture on a carburettor. After this, you may need to
    adjust the idle speed control at the throttle body to adjust the idle
    revs. If you do this, go back and re-check the mixture setting.
    Now move to the flow control in the pipe between the vap and the
    mixer. Screw this down to about half closed. Now rev the engine to
    about half its maximum and fix the throttle there (a screwdriver
    wedged in the linkage does it for me). Screw the valve in further
    until the revs pick up a little. Screw past this point and then back
    off to find it's maximum again. This should now be set at the optimum
    for maximum power - too far out and it will be too rich up the rev
    range, leading to flat spots. Some people suggest screwing it in a
    turn or two for better economy.
    hope this helps
    all the best......mark
    who runs his daily driver on lpg
    BTW ......THE VAPORIZER.....is the round circler thing that vaporises the propane and is heated by water.......from this a pipe go's too the top of the carb were there is a dohnut shaped thing called a mixer.....this mixes the vaporized propane with the air.
  16. #16
    Feb 2004
    Kiron IA USA
    408
    7
    Picture of the forklift I made this winter.
    http://www2.freepichosting.com/Images/421461210/0.jpg
    http://www2.freepichosting.com/Images/421461210/1.jpg
    I started with an airport tractor and a mast from a battery lift.
    [This message has been edited by YoungDen (edited 02-29-2004).]
  17. #17
    Oct 2001
    San Jose, Ca. USA "That light at the end of the tunnel just might be......"
    2,244
    13
    That looks mean enough to be able to plow the driveway too, got a scoop for it yet ?
    TMD
  18. #18
    Jan 2004
    2,892
    5
    Gotta scoop too.
  19. #19
    Dec 2003
    BC Canada
    198
    Another potential problem is the vaporizer getting gunked up on the coolant side and heat not transferring from the coolant to vapourize the propane. Thus, even if coolant temp and flow are okay you don't get enough vapor.
  20. #20
    Oct 2003
    Miami, FL, USA
    68
    youngden,
    that is the most MESSED UP thing ive ever seen. where can i buy one?! lol whats moving it? slat six, or a ford 300? did you correct it so it has more forward gears (now driving in reverse), or do you have one speed only going forward? whats the axle from??
    very cool. ive always thought tugs were really cool.. maybe ill own one some day...
    DON,
    my generator's engine came from a forklift. its a flathead 4 continental using a brand new impco lpg system. i once drained the block (the regulator is teh LOWEST point in teh system), when i refilled it aparently i didnt get the regulator primed up. started and ran it, all the sudden my eyes burned and then motor shut down.. looked at the regulator, it was a block of ice.. boiled soem water and thawed it. i had to take off a hose and pour water in to prime it..
    my eventual solution was this: on the bottom of the regulator i installed a T fitting, one side going to the coolant hose, the other side going to a ball valve and then to a garden hose bib. when i drain the block now, all i do is hook up the hose and open the valve until water comes out the radiator. works fine and havent had a problem since. perhaps youc an run watre from your hot water heater through a hose and do the same thing on cold days... just an idea.
    -m
