Drill points - 118 vs. 135 for home shop usage?
J. Elliott
Hot Rolled
May 18, 2002
Boonville, NC 27011
Fellas,
I've got a line on a decent set of cobalt drills, but they are 135 degree 'heavy-duty' drills. Not 'production grade' 118 degree. I joined up at tech school a semester late, after they'd taught drill grinding, and am sitting here realizing I don't have a good handle on the difference. Plus, I don't think we ever used anything other than normal drills at school anyway....
I know I've never sharpened anything exotic. Is a 135 split-point cobalt something that can be touched up on a regular grinder? Or do you need a fancy drill grinder with a proper split-point setup?
Mainly though, would 135 degree split point cobalt drills make a good all-purpose drill in a home-shop envirnment? I'm completely in the dark about 118 vs. 135, performance and longevity wise.
Many thanks for y'all's time.
As I understand it, the 118 is better for more abrasive material. The 135 works better on harder material and has a longer life to the edge it seems. (Correct me if I am wrong people). I like the 135 for steel and hardwoods. But it does have a tendency to bite more at the exit point than the 118 when you are doing a through hole.
Drill Doctor 400 and above can sharpen the split points on the 135s and 118s, and trying to do a proper split point on the grinder is a paine unless you have a precise jig. (Unless you are one of the older gentlemen on this board who have been doing this since creation. :D )
In industry, 118 degree are considered "all-purpose", whereas 135 degree are generally preferred for tougher materials. How much difference it makes to the bottom line at the end of the day, I haven't a clue.
To answer your question directly, a 135 degree point will work great in a general shop environment. Split points greatly help in starting the drill and keeping it on center.
Essentially, there is an optimum grind for every type of material. It can make a HUGE difference in how well the drill cuts, hole size and hole finish. See any of the drill maker sites for suggested drill angles on various materials.
I always grind the tip rake for brass, but unless I'm doing a lot of holes in one kind of material, I'll generally go with the general 118 or 135 degrees and not grind the optimum angle for that material. I always split the points when I'm resharpening but I have a drill grinder.
George
if you use them at home in a hand drill. I would go with the 135's. I like them a lot especially in cobalt.....most of the time you wont drill a small hole and then go larger....especially if its under .5" you just garb a drill and go...well the web thickness can hurt you, because it doesnt cut as easy if its not split.....and since your using hand pressure instead of machine feed...life would be easier with the 135 splits. But you wont be sharpening them at home by hand!... they cant besharpened very well with out the split point.. the web is just too thick.....if you have a drill sharpener, then you ar good to go......I think in a large drill with a 118 point... it will heaat up more...because the is more surface are cutting on the drill... couple with the fact it isnt a center cutting drill( in first pass holes)...so the material in the center is just getting RUBBED to death...but a split point cuts all the way to the very center................good luck...bob
The 118 degree points are used for general purpose drilling in mild steel and other soft material. The 135 degree points are usually used in harder high alloy materials. The cobalt drills will take more heat before the cutting edge breaks down but they will chip easier if you force them. As started in other posts there is an optimal point angle for materials along with speed and feed. Split points will help guide the drill in straight and aid in cutting at the tip. Depends on who you talk about sharping drills by hand and spliting points without a sharpener. I have a Darex sharpener that does an very good job if it is set up and used properly.
The web of a drill bit gets thicker the further you get away from the tip. If you resharpen a drill bit many times the web is thicker and the point should be split even on 118 degree points.
Joe
you need a nice sharp corner at the edge of your stone, and a good understanding for the cut/angle you want to end up with (practice). (after many test runs). and then you have your own creation.
heat / presure
Still you have less cutting edge working which means less pressure to drill. This analysis ignores the advantage of the split point, that makes drilling even easier.
Your points are well thought.
On rare occasions when we got a break, to look busy we would practice hand grinding the relief edge of a drill bit so as to start drilling and then let off the pressure and it would finish the cut through by itself. this would also be one continuous curl start to finish. and make one of the cleanest exit holes.
some of the old boys could easily hand grind a starter tip and split it on larger bits. something you don't see much any more. ahh... the art of machining....
and as the bit screwed down through the metal it would pass through cooler metal because of an accurate curl sending more heat out of the cut then pushing crumbs and chips out on the fluke of the bit which holds more heat in.
yes and Hi. he/they are only 4 yrs past you.
still want to leave a path for new comers to learn and wonder.. and your quick reply shows someone is still at the helm. its easy for people to feel old and show signs of wisdom (gray hair). its very hard to look wise and needed. but as for luck, Google will search and Guide the masses to Heat Split point and Pressure where a fossil can try to share there wisdom and the grace of how things used to be done and pride in our work and achievements. end of rambling.
If you had got these drills with no writing telling you they were 135, you would most likely would have never known a difference. Buy what ever you get the best deal on, stay away from those $20 complete sets with the super duper coatings though..their bullshit.
That there is the definitive answer...
