Rusty Bates
- Dec 18, 2004
- Winston-Salem, NC
I built a small reversing gear box for a model project using a weedwacker motor. Motor output RPM's is about 3000. Construction is simple with spur gears.
Input and output shafts for gearbox are mounted onto oillite bearings. First used 90wt gear oil but found major oil leakage at bearings. Could grease be used instead and if so could someone kindly point out a good grade and brand? Also if grease can be used should box be packed almost full?
Any comments, help would be welcomed!
BTW, model project can be seen at http://www.geocities.com/eastpac01/index.html
Thanks, Rusty
Thanks, Rusty
