Results 1 to 3 of 3
    lt1pat is offline Member
    Oct 2005
    Detroit
    51
    Post
    Is it possible to have my TNC360 Heidenhain control to pull more upcoming code in a drip feed situation? Im having problems with my machine using the code at a faster rate that it can pull in some high detail situations while it could be catching up when its doing the simple stuff. The transfer rate is set for 9600 and I can't load the program because my machine won't hold more than 1,000 lines at a time and the program im trying to run is 56,000 lines.
    FarmallMan is offline Senior Member
    Jul 2004
    Troy, NY, USA
    969
    Post
    Can you run a higher baud rate with flow control? The flow control should prevent the buffer from overflowing.
    Nick
    Boris is offline Titanium
    Oct 2005
    England
    2,876
    Post
    Hi there
    This post should really be in the CNC section ( where the advice is free, turrets are misaligned and Mr Slammy looks for victims* )
    Ok more seriously.
    Change to a faster baud rate
    Mod button --- RS232 setup.... change and enter , Of course you'll have to change the PC baud rate too, And be aware that the longer the cable between the PC and TNC and the faster you go, the more chance there is of an error creeping in.(line noise)
    If you are running drip feeds successfully at the moment, there should not be any real reason to fiddle with the flow control.
    Hope this helps a bit
    Boris
    * Mr Slammy means my 3 lb lump hammer and victims means lazy or misbehaving operators at my place of employment
