Helix angle calculation – thread dial
Results 1 to 8 of 8
    May 2004
    Nebraska
    413
    14
    Post
    Can someone post the calculation for thread helix angles? I need to make a thread dial for a Stanley Engine, the Major Dia. on the screw is 2.25 with 2 TPI. If my figures are right the pitch Dia. is 2”. I didn’t get any manuals with this machine so if someone could help me out here, that too would be appreciated. Stanley 1704 made in Halifax England.
    Oct 2003
    East Peoria, IL, USA
    5,226
    288
    683
    Post
    being a zero load appication it doesn't really matter.
    and far easier to tell you that than to figure it out. [img]smile.gif[/img]
    Jul 2004
    Houston, TX USA
    27,201
    Post
    If 2" P.D.:
    (2.000 X 3.14159) divided into .500" = 0.07958 = tan of 4.55 degrees.
    John
    Nov 2003
    Colorado
    3,211
    1967
    3841
    Post
    If you don't mind having a canted threading dial, make a mount for it that allows you to tilt it to line the teeth up with the leadscrew.
    May 2004
    Nebraska
    413
    14
    Post
    I don’t have a problem with a canted or tilted thread dial but I didn’t think it would be a problem to apply the helix angle to the teeth on the spur gear either. My experience with gears is fairly limited, machined a few straight tooth spur gears on horizontals but that’s about it. What am I over looking?
    Apr 2004
    Hazelton, Idaho, U.S.A.
    119
    15
    Post
    I have made several of these threading dials. All I did was to fixture the blank at the appropriate angle, I measured mine to get a good enough approximation, then ground a single point tool that matched the thread profile. Then it was just a matter of turning the crank on the dividing head and gashing out the teeth. Not very pretty but very functional and takes less time than making a hob.
    -brian
    Nov 2003
    Beaumont, TX, USA
    4,050
    126
    1061
    Post
    Acme thread is very symetrical. Measure the OD or Major Diameter. Measure the Minor Diameter. Add them together and divide by two for the pitch diameter. Multiply pitch diameter by pi (3.141) to get the circumference at the pitch diameter. Divide the lead (1/TPI if Engilish) by the pitch circumference and take the arc tangent of that value to find the helix angle.
    Overall formula:
    HA = arctan(L/((OD+MD)*3.141/2))
    HA is Helix Angle
    L is Lead
    OD is Outside Diameter
    MD is Minor Diameter
    Be sure all measurements are in the same units.
    Paul A.
    Apr 2005
    Vallejo,Ca USA
    207
    Post
    The gear on my Emco Maier V-13 is thin, about 1/16" thick so helix angle does'nt matter.If your lathe lead screw does'nt have a slot in it for power feed you can make your gear the same.
