How can I drill into a ball bearing?
Page 1 of 2 12 LastLast
Results 1 to 20 of 36
    May 2004
    St Louis
    477
    Post
    I have some 7/8 or 1" ball bearings, I want to drill a 1/4 inch hole half way into them.
    What are my options?
    I havn't tried heating them up first to see if that will soften them, would that work?
    OR
    What is another source for a 7/8 1" steel sphere that I can drill into. They need to be smooth, but not chrome plated smooth.
    HSS steel bit doesnt cut it.
    I don't have a radius cutter for my lathe and I dont think I have time to build one.
    Thanks for your .02
    Jun 2004
    titusville fl. usa
    3,619
    14
    Post
    GOOD LUCK!
    what you need to do is either get a ram type EDM and burn those holes in there or get onto McMaster~Carr's web site and order some soft spheres...jim
    Aug 2005
    Hernando, FL
    6,523
    1511
    2161
    Post
    If you have a solid setup you could drill into it with a good carbide spade drill.
    Oct 2001
    Montrose Iowa
    1,180
    Post
    How I have done some is to put the ball in a collet and use a carbide bit, I like the Hi-roc bits, not the twist type, for this kind of hard stuff. They will drill up to about 60C, could be that bearings ar too hard even for carbide.
    Feb 2002
    Peralta, NM USA
    5,430
    40
    327
    Post
    McMaster lists 1" steel balls from AISI 1020 (soft stuff) as 96455K62. $15 bucks for 25 balls. They're case hardened but I would expect that the case could be ground off deep enough that you could drill it in no time. If not, these could be annealed pretty easily.
    You might anneal the existing bearing balls by heating them past critical, holding them at temp for about 15 minutes and slow cooling them. But a lot of bearing balls are made from 52100 and are not trivial to anneal, but that being said you would likely be able to soften them up enough to drill a hole.
    Mar 2004
    Granada Hills, CA
    498
    Post
    Funny...I have the exact same problem...I am going to try tossing mine in our furnace at 1700F ish...and letting them furnace cool.
    The auction said "Nickel Plated Steel Balls" Not...UBER-Hard Stainless balls...
    Shoulda done a hardness check before i buggered up a center drill.
    NK
    Nov 2002
    Oakdale, MN USA
    552
    8
    Post
    If you bring them up to a cherry red and hold that for abit and let them air cool you can drill them.
    Apr 2002
    Syracuse, NY USA
    9,588
    16
    538
    Post
    that guy had some balls...
    Feb 2005
    Birmingham, AL
    4,024
    13
    41
    Post
    I have done this. But let that drill get the slightest bit of movement in the work and POW! It'll be gone.
    Mar 2004
    Granada Hills, CA
    498
    Post
    Thank you Surplusjohn. That was pretty good.
    NK
  11. #11
    Jan 2003
    Central Kali.
    1,981
    12
    Post
    I have done this by putting them in the fireplace coals and taking them out the next day. I drilled and tapped them with no problems.
  12. #12
    Aug 2005
    Bayou La Batre Alabama
    177
    Post
    Why do you want to drill hole in your balls ?????
  13. #13
    May 2004
    St Louis
    477
    Post
    Good, heating them is cheap, but I will look into Mcmaster cheap soft spheres.
  14. #14
    Apr 2003
    Portland, ME, USA
    2,086
    Post
    I recently had to do a job involving drilling into hard bearings/bushings. One had a series of holes 2mm diam x 30mm deep!
    Get a Hi-Roc drill, I think they are made my MA Ford. They are carbide, straight flute. I had no problem drilling Rc64 with them. Tool life was short (about 10" of drilling on 4mm drills), and they aren't cheap, but what a beautiful hole.
    It sounded like someone swinging a cat by his tail- but you cannot argue with the results. Flood coolant, and clamp your axes if you are in a b'pt or the like.
  15. #15
    Nov 2001
    WAPELLO, IA USA
    6,425
    29
    1815
    Post
    I don't know how many you have to do, but I have some experience removing cutters after cnc crashes( sometimes a little oops happens and I have a 1/2 spot drill stuck 1-1/2 inches deep in a part... usually after a software update). a carbide endmill in a nice rigid setup will cut M2, M42, T15, most of you performance high speed steels. I have even done it on my radial drill, but my radial has a stiffer spindle than my HBM.
  16. #16
    Oct 2005
    tacoma washington
    1,338
    27
    Post
    just bring em up to a dull red and let em cool.
    then use a cobalt bit, and they will drill right thru, just keep em cool and steady pressure.
    i have done it many times for spinner knobs, and just to prove it can be done.
    bob g
  17. #17
    Oct 2005
    tacoma washington
    1,338
    27
    Post
    and i you wanna freak out the uninformed
    reheat to dull red, and drop in a bucket of water, then put on a mandrel and buff back to bright and shiney
    it will be hard as glass, and really freaks folks out that cant even get a file to touch it figuring out how you drilled a hole in it. [img]smile.gif[/img]
    bob g
  18. #18
    Nov 2005
    N E Florida
    1,995
    169
    Post
    If you go to McMaster-Carr and do a search for "Steel Ball Knobs" they have from 3/4" to 1 7/8" that are threaded. The 1" comes from 10-24 tpi to 3/8"-16 tpi. They list them as "polished steel knobs, turned from bar stock". Also have Brass, Alum and Stainless. tim
  19. #19
    Mar 2005
    MN
    69
    Post
    make a box jig. square up two peices of steel, say 1"x1" by .5 thick. Ball end mill on center. go shallow w/ same radius as ball. Clamp together in vise and drill thru top of top jig and into ball. No drill walk and the drill/end mill is supported the whole way thru.
  20. #20
    May 2004
    Chilliwack B.C. Canada
    700
    Post
    I suppose you could hold them in a chuck directly for drilling from the tailstock, but you might mark up the surface. You could do as I once did, and that's to mount a stub of rod a little larger than the ball diameter, drill and bore to just under the od of the ball, then force the ball into the hole for turning. You would drill a cross hole in the stub before inserting the ball so you have a way of poking the ball out again. I used a piece of music wire for a poker. Ground a suitable spade shape on the end. Worked for me, and I did first heat the ball to red hot and let cool slowly. I drilled with hss and got away with it, even tapped the hole a short way. I might have used a collet if I had one, but no way would I have had one .405, or whatever that seemingly non-standard ball size was.
