GlennM
- Aug 14, 2004
- Kingston, WA
Several times in the past I've needed expanding mandrels. I could have used the between-centers type or the single-ended type seen on 5C collets. The need was never quite great enough to get me to part with the $$$. Until now.
I think I see how to make the single-end type that can be held in a chuck or collet: turn the mandrel body, slit the end in an X pattern, then drill and tap the end using a taper tap. I'd tap to a shallow depth, so that when the screw is turned in it will reach the unfinished threads quickly and wedge open the slit quarters. It only has to expand a couple thou, but concentricity is important.
If I can dream up one way to do this, there must be about fifty more ways. I'd like to hear how other people make mandrels, particularly the between-centers style. I'm not talking about taper mandrels there; I mean the type that expand concentrically.
All ideas are welcome, especially if accompanied by a drawing.
Thanks!
- Glenn M
Thanks!
- Glenn M
