awake
Titanium
- Jan 24, 2006
- Angier, North Carolina
Greetings! I have been coming down with the metalworking virus ... to the point that I recently bought a Cincinnati Traytop 12-1/2 x 30 lathe. It is in fair condition; I've been doing some cleanup, and I've had to repair or recreate a few things -- new sight glasses, a new wrench for the spindle lock, etc.
One thing on this lathe has me baffled. It has a clutch that engages when you lift up on a lever (actually two levers, one at the gearbox and one the rides along with the apron). This lever turns a square shaft, which works through a couple of linkages to turn a lever inside the gearhead to engage the clutch. So far, so good.
Here's the problem: I can't for the life of me figure out how the clutch is supposed to stay engaged. There doesn't seem to be any sort of over-center mechanism anywhere in the linkage or in the clutch itself. I can't feel any hint of a detent anywhere in the mechanism. Right now, if I let go of the lever, it promptly falls down and the clutch disengages.
Does anybody have a Cincinnati lathe? Can anybody point me in the right direction to figure this out? Any help will be greatly appreciated!
Andy
Andy
