How to tell gear pressure angles 20* vs 14 1/2*
amoretti
Dec 29, 2004
Thermopolis, Wyo
Bought a coil winder but need some different change gears to wind the size wire I want.
Question- how do I determine the pressure angle of the existing gears?? The catalogs warn that the pressure angles are not compatable.
Thanks, John
Pressure angle
Sir,
There are some brass geartooth gauges which are available for a small fee. These come as a bunch of different diametral pitches AND pressure angles. I even had one that was plastic at one time. Reid Tool Supply has one (steel) at $88.00 ! ! ! You ought to be able to find a cheaper version somewhere!.
Regards,
Jack C
geartooth gauges-anyone got a spare??
A gauge sounds like the way to go! Does anyone have a spare they would be willing to part with?? I only need one for 32 pitch. Willing to pay of course.
TIA, John
I copied this tip from an earlier thread on the same subject. Sorry but I can't credit the original poster, I didn't copy his name!
as long as you know the 'DP' of the gear the following will give you a good guide to the 'PA'. take a measurement over any number of teeth with whatever equipment you have,multiply the cosine of the 'PA' by 3.1416 and the divide by the 'DP' add this to your measurement, this should be the measurement over one more tooth if its not the same, change the cosine of the 'PA' and try again. example 10dp 14.5pa 30 teeth, the meas over 3 teeth .776,cos.986147 multiplied by 3.1416 and divided by 10 = .304 add .776=1.080 over 4 teeth.hope this helps
20 degree pressure angle gears are much more "pyramid" shaped than 14.5's. They are very easily recognised once you take a look at the 2 types.
What does 'take a measurement' mean? Over pins, across the chords, at what depth?
Get a worm of modelling clay on the bench and roll a gear along it, cut through the impression (along the length of the worm) and look at the tooth angle of the rack you have made in the clay, it is easy to measure the angle, send the $88 to me!
Peter
