How to tell gear pressure angles 20* vs 14 1/2*
Results 1 to 13 of 13
    Dec 2004
    Thermopolis, Wyo
    101
    Default How to tell gear pressure angles 20* vs 14 1/2*
    Bought a coil winder but need some different change gears to wind the size wire I want.
    Question- how do I determine the pressure angle of the existing gears?? The catalogs warn that the pressure angles are not compatable.
    Thanks, John
    Mar 2003
    Arlington Hts, IL, USA
    75
    Default Pressure angle
    Sir,
    There are some brass geartooth gauges which are available for a small fee. These come as a bunch of different diametral pitches AND pressure angles. I even had one that was plastic at one time. Reid Tool Supply has one (steel) at $88.00 ! ! ! You ought to be able to find a cheaper version somewhere!.
    Regards,
    Jack C
    Dec 2004
    Thermopolis, Wyo
    101
    Default geartooth gauges-anyone got a spare??
    A gauge sounds like the way to go! Does anyone have a spare they would be willing to part with?? I only need one for 32 pitch. Willing to pay of course.
    TIA, John
    Aug 2002
    Northern Ontario Canada
    276
    Take the gear to your local bearing supplier they should have a set of guages to check the pressure angle.
    May 2002
    South Central PA
    12,667
    1661
    2824
    I copied this tip from an earlier thread on the same subject. Sorry but I can't credit the original poster, I didn't copy his name!
    as long as you know the 'DP' of the gear the following will give you a good guide to the 'PA'. take a measurement over any number of teeth with whatever equipment you have,multiply the cosine of the 'PA' by 3.1416 and the divide by the 'DP' add this to your measurement, this should be the measurement over one more tooth if its not the same, change the cosine of the 'PA' and try again. example 10dp 14.5pa 30 teeth, the meas over 3 teeth .776,cos.986147 multiplied by 3.1416 and divided by 10 = .304 add .776=1.080 over 4 teeth.hope this helps
    Oct 2006
    williamsburg va
    7,886
    839
    1713
    20 degree pressure angle gears are much more "pyramid" shaped than 14.5's. They are very easily recognised once you take a look at the 2 types.
    Jun 2007
    New Zealand
    2,661
    28
    Thanks Mudflap for reposting that handy tip
    Jul 2004
    Houston, TX USA
    27,446
    Like Mr. Wilson says - 20° is more "pointy" and 14 1/2° is more square ended - same in the root.
    Feb 2008
    Paradise , California
    1,745
    259
    398
    INTERESTING- Jess
    Jan 2005
    CANADA
    Saskatchewan
    9,527
    1163
    3242
    What does 'take a measurement' mean? Over pins, across the chords, at what depth?
  11. #11
    May 2002
    South Central PA
    12,667
    1661
    2824
    Quote Originally Posted by HuFlungDung View Post
    [font=Verdana]
    I took it to be a span over teeth measurement. Just use a dial caliper.
  12. #12
    Jan 2008
    Utah
    195
    Quote Originally Posted by johnoder View Post
    Here is a link to a web page with a diagram:
    http://shopswarf.orcon.net.nz/spur.html
  13. #13
    Sep 2004
    Rugeley UK
    958
    20
    97
    Get a worm of modelling clay on the bench and roll a gear along it, cut through the impression (along the length of the worm) and look at the tooth angle of the rack you have made in the clay, it is easy to measure the angle, send the $88 to me!
    Peter
