300TD4x4
- May 15, 2003
- Pollock Pines, CA, USA
What is the correct method for turning a piston? Is there any way to do it with the rod still attached? They are not full floaters and don't want to risk breaking a piston removind the wrist pins.
I was thinking maybe I could make a small plate that the rod bolts would go through. I would put a 3rd hole in it for my tail stock center then grab the crown with my 3 jaw. This might work for the skirt area but when I try to do the ring pack area I was thinking maybe I would press a pin through the 3rd hole mentioned above, grab that with my 3 jaw and use a steady rest to go around the circumferance? This does not sound too practical. I suppose I could perhaps JB Weld an aluminum block to the top of the crown and maybe center drill that.
Sorry to ramble and I may not be making any sense. Any constructive ideas are appreciated. Any "Don't do its" please don't respond.
Brian
Brian
