kinda OT: leg/post vise mounting.
Results 1 to 5 of 5
    Jun 2004
    Grand Rapids, MN USA
    85
    Post
    I have a leg vise I am going to install in my garage. I am wondering if I should put something under the leg to spread the load on the concrete. I was thinking maybe a 6"x6"x3/4" piece of hardwood or steel plate.
    Brian_h
    Jan 2002
    home
    1,025
    Post
    my favorite vice was on a 2' x 2' chunk of steel and had a pipe post down to a 2' x 2' chunk of steel bolted to the floor.
    no sense in chasing the vice around the shop.
    the table made a nice little welding and brazing table too.
    Jan 2004
    Bergton VA USA
    196
    Post
    Brian,
    You really don't need much under the post so your idea is more than enough. As Mike said, SECURING the leg is probably at least as important. I usually make an 'L' shaped bracket to bolt against the workbench. It has a hole on the bottom that the leg fits into. Then I just put wood or steel scrap underneath that. Most leg vises have a shoulder about 1" or so from the bottom for just that reason.
    Feb 2004
    Metuchen, NJ, USA
    5,366
    3987
    798
    Post
    Brian,
    You are on the right track, because the whole purpose of the leg on a blacksmith-style leg vise is to transmit the force of a hammer blow to the FLOOR, as opposed to the bench.
    The weight of the vise should be on the leg. The attachment to the bench is just to keep it upright.
    Whatever supports the leg must withstand the heaviest blow you intend to impart to the work. If you are going to wallop your work with a big hand sledge.......you can guess what would happen to a concrete floor.
    Some smiths mount these on an upright timber embedded in the floor, with a second upright timber flush with the floor right in front of it. The leg goes into a socket drilled in the top of the timber that is flush with the floor. The end of this sunken timber was bound with a tight iron band. (Which may have been shrunken on like a wagon wheel's iron tire.)
    The cross sections of these timbers is about the same as a RR tie.
    The top of the taller upright has a thick horizontal hardwood plank just big enough to take the upper mounting plate of the vise. There are diagonal wooden reinforcing "cheeks" holding this plank to the top of the tall upright. The cheeks are through-bolted.
    Saw this in the blacksmith shop at Allaire State Park - they have four vises set up this way, one for each forge. One could readily see that this would take whatever blow that the vise itself could withstand, and transmit that blow directly to the earth.
    Just remember that the whole point of a leg vise is so you can "whale" on it without pounding your bench, or the concrete floor, to smithereens.
    John Ruth
    Jun 2004
    85
    Post
    Thanks guys
    I drilled a hole halfway through an oak 2x4. Then I fastened the tail of the 2x4 to the workbench leg. The leg of the vise sits in the hole and the shoulder near the bottom of the leg rests on the top of the 2x4. I haven't done any real heavy pounding on it yet, but it will get a workout soon enough.
    A story on the vise. I got it from a guy that was using it for a yard ornament back in the late 80's early 90's. It was painted pastel pink and green. (I really could have used a barfing gremlin had it been available). But seeing as I paid $5.00 for it, I'm not complaining.
