Lathe thread depth chart?
Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Sep 2005
    Iowa
    19
    Post
    Hi all:
    I did a search but didn't come up with any good links.
    I am looking for a thread depth chart. Not the calc of .75 divided by threads/in. I mean the actual depth of the threads or the "minor external diamension" subtracted from the "major external dimension".
    I don't always cut with the compound, but just use the cross.
    Jake
    Jan 2006
    Houston, TX
    6,087
    565
    1027
    Post
    Do you have a "Machinery's Handbook" ?
    Invest in one... even an OLD one...
    Nov 2003
    Colorado
    3,211
    1967
    3843
    Post
    Divide one by the threads per inch and then multiply by .866
    Example: 16 threads per inch
    1/16 = .0625
    .0625 x .866 = .054 single depth of thread
    If you need a chart, work the formula above for all the common threads and make your own chart.
    Nov 2002
    Southern Indiana
    465
    Post
    Hi Jake,
    I have a thread gage (sometimes called a fishtail)that has the double depths listed for most of the threads. If you don't have one, I suggest getting one. They're handy for grinding and setting up thread tools too.
    If that isn't available, I just work from the one that I have memorized; 20 TPI = .065 double depth.
    As an example, say that you want to cut 16 TPI.
    20/16 = 1.25
    1.25 X .065 = .081
    16 TPI = .081 double depth.
    Works for me anyway.
    Mike
    Oct 2002
    Los Angeles, CA, USA
    140
    Post
    Go to my page, download DOT (Depth Of Thread), run it and you'll get an output
    that looks like this...
    DEPTH OF THREAD CALCULATIONS
    Threads angle [60 deg] ?
    Threads per inch [20] ? 16
    Compound rest angle [29 deg] ?
    thread angle = 60.00 deg
    threads per inch = 16.0 (pitch = 0.06250 in/thread)
    {compound feed at compound angle = 29.0 deg}
    (A) dot sharp crest - sharp root = 0.05413 in {0.06189 in}
    (B) dot flat crest - flat root = 0.03383 in {0.03868 in}
    (C) dot sharp crest - flat root = 0.04059 in {0.04641 in}
    (D) dot flat crest - sharp root = 0.04736 in {0.05415 in}
    (E) double dot sharp crest - sharp root = 0.10825 in
    For American National (60 deg) thread form, subtract 0.0406 in from
    major diameter (assumes p/8 flat on crest) to obtain pitch diameter
    use any line on threading dial
    Regards, Marv
    Home Shop Freeware - Tools for People Who Build Things
    http://www.myvirtualnetwork.com/mklotz
    Jan 2006
    Houston, TX
    6,087
    565
    1027
    Post
    Wich one is right?.. Is EITHER RIGHT???
    1/16 = .0625
    OR.........
    20/16 = 1.25
    1.25 X .065 = .081
    Jan 2003
    Canada
    10,743
    4557
    2914
    Post
    Well I'll add another one in there.
    I normaly use this little formula. I'm not sure exactly why its this number works. I think it takes care of the normal root and crest sizes. Anyway, simple as can be. Only 1 number to remember, .625
    .625 devided by whatever TPI #
    .625/16 = aprox .040" depth per side. These numbers are only meant to get you somewhere close, pretty much just like looking at it. When its getting close to a true V shape, you're almost there and should get out the 3wires/ gages, or the mating part.
    I also use this formula for undercuts and I add a bit more for clearance. I never had any complaints.
    Jan 2006
    Houston, TX
    6,087
    565
    1027
    Post
    So far NOBODY agrees... this is NOT funny....
    but somehow I sorta expect it...
    Do any of you make threads to the BOOK ?
    Get a "Machinery's Handbook"
    Every one of you would be royally Pi$$ed if the spark plugs you bought were made using your methods...
    Sep 2005
    Iowa
    19
    Post
    So what does the Machinery Handbook say?
    Jake
    Nov 2003
    Colorado
    3,211
    1967
    3843
    Post
    1/16 = .0625
    OR.........
    20/16 = 1.25
    1.25 X .065 = .081
    Why don't you get your BOOK out and see which one is right?
  11. #11
    Nov 2002
    Southern Indiana
    465
    Post
    Gary E,
    By the time you have the thread data found in the handbook, The thread could already be cut! It just isn't all that technical.
    I stand by my "formula". I use that because I happen to be able to remember it.
    Another way to do it:
    Pitch X 1.3 = double depth (Handbook worshippers will probably want to use 1.299 in place of 1.3)
    These numbers are not for a pointed tool, but rather for a tool that has a proper flat at the tip. I think that this is where the descrepency comes from. The single depth of a thread with a sharp root is indeed .866 X pitch. These threads are weaker though.
    Incidently, all this was derived from the "Greenfield Screw Thread Manual" which I believe is still in print.
    Mike
  12. #12
    Sep 2005
    Iowa
    19
    Post
    Well, I must say I have calculated each of your formulas including the DOT program and none of you are the same.
    Since I don't have a handbook, what does it say?
    Jake
  13. #13
    Jan 2003
    Canada
    10,743
    4557
    2914
    Post
    It says it doesn't matter how you want to calculate it as long as the end result is good.
    Going with only a calculated depth without checking with 3wires or a ring gage is NOT acceptable in normal production where many parts have to interchange.
  14. #14
    Oct 2002
    140
    Post
    Here you go...
    http://homepages.tesco.net/~A10bsa/uncpro.htm
    Regards, Marv
  15. #15
    Oct 2002
    140
    Post
    Here you go...
    Addendum: Note that, from the above page,
    hn = 0.54127/16 = 0.033829
    which agrees exactly with what my program calculates for
    dot-flat crest to flat root.
    Regards, Marv
  16. #16
    Nov 2002
    Southern Indiana
    465
    Post
    SND,
    Good point. A formula is only good for getting you in the ballpark. Always stop feeding in a few thou shy of the calculated position and start gaging for the last bit.
  17. #17
    May 2005
    Republic of Arizonia
    1,430
    369
    Post
    .130 / number of threads per inch
    example .130 / 12 = .01083333333
    For 75% thread I believe
  18. #18
    Sep 2005
    Iowa
    19
    Post
    JS:
    That is sounding good. My fishscale says .93 for 14tpi.
    so 13/14 = .92857
    .92857/2 = cross slide depth
    Correct?
    Jake
  19. #19
    Sep 2004
    south SF Bay area, California
    1,917
    108
    564
    Post
    Jake --
    The Theoretical Single Depth of Thread for either the Unified or ISO Metric threadform -- which are both 60-degree threads with a 1/8 Pitch flat at the Major Diameter and a 1/4 Pitch flat at the Minor Diameter -- can be calculated easily from the Thread Pitch:
    Theoretical Single Depth = (5/8) x Pitch x Cos (30 degrees)
    Working a numerical example for a Unified threadform of 1/16 inch Pitch:
    Theoretical Single Depth = (5/8) x 1/16 inch x Cos (30 degrees)
    = 0.625 x 0.0625 inch x 0.866
    = 0.0338 inch
    Working a numerical example for an ISO Metric threadform of 1.25 millimeter Pitch:
    Theoretical Single Depth = (5/8) x 1.25 millimeter x Cos (30 degrees)
    = 0.625 x 1.25 millimeter x 0.866
    = 0.677 millimeter
    The Unified and ISO Metric threadforms are modified (truncated) V screwthreads with a 60-degree included angle between the flanks. In a 60-degree Sharp-V screwthread, the measured-along-the-flank length would be exactly equal to the Pitch. The flats at the Major and Minor Diameters on the Unified and ISO Metric threadforms result in a reduction of the measured-along-flank length to 5/8 that of a same-pitch Sharp-V screwthread. [This means that the Theoretical Along-Flank Infeed of a compound / top slide set at 30 degrees to feed along the flank can be calculated as (5/8) x Pitch, which for a Unified threadform is exactly equal to (5/8) / Number of Threads per Inch.]
    The Single Depth of the screwthread is the measured-along-flank length of the screwthread times the Cosine of one-half of the V angle.
    Ok, the arithmetic says you can combine the 5/8 and Cos (30 degree) factors to create a "magic number", but doing so is a BAD idea. It would be far better to learn the fundamental geometry of the Unified / ISO Metric threadform well enough that you can re-derive the equations whenever you need them.
    That geometry really is pretty straight-forward, and once your understand it, the terms 5/8 and Cosine (30 degree) will come to mind far more readily and reliably than will magic numbers.
    John
  20. Likes Paul Jones liked this post
  21. #20
    Dec 2000
    Bremerton WA USA
    10,633
    40
    4048
    Post
    I'm the only right one here. I hardly ever calculate thread data. I cut threads until they look like a thread then gage them with the nut or male thread, mike them over wires, or thread mike them if they're in range of the thread mikes I have.
    I also cut threads with the standard root flat P/4 to P/6) on the tool tip. Never cut threads with a pointy tool.
    All the thread data and the NIST formulae it takes to derive it from scratch are in Machinery's Handbook.
