I have found an old 1940's Leblond Regal lathe.
It has the speed control dial on top of the headstock and the number 13 cast into front of the headstock, I could not find a serial number.
The owner wants $1200.00 for it and I am trying to find out if it is worth it.
Other then a bad motor it appears to be in good condition.
You can still see some of the scrapings and where there are no scrapings it seems that they are just barely worn off.
The carriage seems tight and everything seems to move smoothly by hand.
It could not be run because of the bad motor.
It has a 3 jaw and 4 jaw chuck as well as a steady rest and some tooling.
Would I be limiting what I can do on the lathe by going with a lathe this old?
Can you use collets with this lathe?
How do you thread on this lathe as there is not thread dial on the carriage?
Please bare with me as this would be my first lathe and I do not know very much about it.
George
George
