Orrin
Hot Rolled
- Mar 17, 2004
- Colton, WA USA
I have a hare-brained idea for coaxing a little bit of accuracy of a lathe with worn ways. I'd welcome comments.
First, a bit of a background. Out here in the sticks where machine tools are scarce, I've given up on ever finding an accurate lathe. I have two Sheldons, I had high hopes for one of them, but as it turned out, it produces a very serious taper.
In its first lifetime, my other lathe was used in an automotive shop for doing commutator work. Therefore, all the wear on the ways is over a very small area.
Here's my idea. For the rare occasions when I need to turn something accurately between centers, I could chuck up a 6-inch length of sturdy drill rod and turn a 60° taper (center) on the outboard end.
That way, I'd shift the carriage travel out beyond the worn spot, where the ways are pristine and like new.
What do you think?
Of course, I'd have to jury-rig a catch-plate and I might have to add the support of a steady rest near the outboard end.
As I see it, the extended center would be no more flimsy than the protruding 5C collet adapters that are made for lathes with spindle bores too small to accomodate the 5C collet.
If this thing would work out, I could make a super-sturdy spindle extension out of 2¾ or 3-inch round stock or heavy wall tubing. It would thread directly onto my 2¼" spindle. The outboard end could have, say, a 1½" X 8 TPI thread, shoulder and register to accomodate small chucks.
I probably wouldn't bother with turning a Morse taper at the far end because I wouldn't mount a center out there, anyway. I usually use ad hoc centers made of chucked round stock.
If this could work, it would put an end to my futile search for an accurate lathe.
Thank you for your comments and suggestions.
Regards,
Orrin
I
What do you think?
Regards,
Orrin
I
