Making a Flat Spring
Results 1 to 5 of 5
    Aug 2003
    Downers Grove, Illinois,USA
    42
    7
    Actually I'm looking for a way to temper a small flat spring for an 80 year old airgun
    Oct 2001
    San Jose, Ca. USA "That light at the end of the tunnel just might be......"
    2,244
    13
    If it is a flat spring, buy a piece of blued spring steel, already tempered and just cut to size. What thickness do you need ?
    TMD
    Dec 2002
    Safford, Az., USA
    1,311
    If I remember right,To anneal a spring, take a tin can that is empty. Turn it over so the open end is down. With your hammer, beat a depression in the top of the can. Place spring in depression and fill with motor oil and light it. When the oil burns away, you should have a spring. Place spring in vise and compress it. Either you will have a spring or it will break.
    Michael
    Mar 2001
    alvaton,ky
    981
    7
    34
    u r looking to draw to a purple color for tempering a light spring up to a blue for a heavy spring maype 550 to 580 depending on time & material .....for a heavy spring u may need to burn it off twice...if u miss it on the far side , u can always reharden it , miss it on the near side , & u will remake it !......near 60 yrs ago ,i was taught to check for color in a somewhat dark corner of the shop ( no direct light ) when initially heating to a cooked carrot color for hardening ..& as stated, when u compress a folded mainspring for a double , like der alte buschenmeister hat gesagt ,,,"u hef a schpring ,or u aint"
    Dec 2002
    Pacific NW
    4,990
    7
    783
    For info on springs try this site.
    http://home.earthlink.net/~bazillion/intro.html
