Michael Moore
Titanium
- Jun 4, 2004
- San Francisco, CA
I've seen a lot of photos of different mills/lathes with voluminous chip pans.
I find myself wondering if people have to rake/shovel the swarf out of them, or do they have panels in the base that can be slid/dropped to let the swarf fall into a bucket?
Being able to push the chips down into a bucket through a hole seems a lot easier than pulling them up and out of the pan.
Is this one of those features that is so obvious that no one mentions it, or has it never occured to a manufacturer to make it easy on the machine owner to clean out the swarf?
I do realize that if a lot of coolant is used any trap door in the bottom of the pan will need a good seal so coolant doesn't leak all over. But it seems like the opening could be raised an inch or so above the floor of the pan so that coolant has a chance to drain before rising to the level of the trapdoor, and still leave it pretty easy to push the chips down and out.
cheers,
Michael
cheers,
Michael
