Appie Chappie
- Feb 13, 2003
- Vredenburg 7380 South Africa
Greetings All,
I am in the market for a large table/long stroke
bed type mill and came across a 2mtr stroke planer
grinder with all slideways in excellent condition.
The machine is overall 11.4 tons with massive dc
varible speed drives which draw 100 amps....too
much for us without going for a transformer.
As this is a +-1978 model, is it not possible to dump the old electics for something more modern?
that would use less power and still be efficient.
We want it to flatten plate liners etc and as it has a grinding head that seems to take a large cup wheel and a horiz/vert heads, seems to be a usefull machine. cost = usd 13,000.
The manual shows very little of the mechanicals,
that are pretty much self explanetory, but the electricals take up a A4 3/4" thick manual showing
wiring and trouble shooting....all in german.
It seems Tos went to great detail to create an
electrical system that works but seemed to accept
the fact that electrical problems would be encountered on a regular basis.
Are planers as outdated as shapers with the modern
milling inserts and feeds? Are there inserts and tooling out there designed to take the impact one
would get with planing?.
A thought came to mind of making a milling head and putting a long leadscrew on the table so one could feed the table to exact co-ords.
Like I said, the machine is in excellent condition
with no scratches on any slides or the bed and I
have a 2m stroke with no table sag or rock. I
want to hold a 0.02mm over the length of the stroke and the 750mm wide table, and from what I see, it may be possible with the right setup.
Any idea's or have you seen any mods to a machine like this?
Andy
Andy
