alrednek
- Aug 6, 2003
- Birmingham, AL USA
I have been cleaning and re-assembling my 12 inch Craftsman lathe (I know it's only a toy to most of you guys, but it fits my needs). I can't seem to get the carriage gib adjusted just right- there must be a procedure that I need to follow. The carriage uses a square edge (not tapered) gib with 4 recesses that the adjusting screws seat into. I've tried several times to adjust the gib and no luck so far. Is there a sequence that I need to follow when adjusting the 4 screws? Tighten inner screws first then outer ones? Start tightening on one end and then go successively to the other?
I'll have the same problem with adjusting the gib on the cross slide too. It is tapered on both edges. Will it adjust the same way?
Thanks for any help or advice you can offer (other than getting rid of the *toy*).
Mike
Mike
