Metric threads on a Clausing 5914?
Results 1 to 5 of 5
    Feb 2003
    Casselberry, FL
    485
    48
    8
    Post
    Threading is not one of my strong points...I need to chase a metric thread on the end of a crankshaft, 1.5 pitch. I have tried to 'fumble around' finding a US tpi equivilent but can't seem to get it...can this be done on my Clausing? FWIW, I only need to chase the end, about 1/2 inch, so if it's not exact that will be fine for this application, just enough to get the nut started.
    BTW no this cannot be cleaned up with a thread file or a die, it is mushroomed over and the diameter is swollen, so it needs to be cut on the lathe. Thanks
    Aug 2001
    Batavia, IL USA
    1,918
    50
    56
    Post
    Clausing sold a metric change gear set for these lathes but they seem to bring a lot of money on the used market ($600+) so that's probably not an option for you. If I did the math right, 1.5 picth is around 16.9 tpi and the closest standard threads on the 5914 are 16 and 18 tpi so that doesn't seem to offer much help either.
    Would it be possible to shave the OD down and then use a die or thread file?
    Mike
    Jun 2006
    Taylorsville Ky
    3,122
    23
    Post
    How big is the crankshaft and whats it fit in? What is the dia. of the thread?
    Feb 2003
    Casselberry, FL
    485
    48
    8
    Post
    Just a followup- Mike I did as you suggested, and as I have done before, turned the OD down, chamfered the end, and then worked it with a thread file first and then a trianglar file, bluing the threads first to contrast where I have filed, then using plenty of oil while trying the nut to help prevent ruining the threads in the nut. Took a little while but came out fine.
    Carl its a Cat 3404
    Thanks-Hanz
    Mar 2005
    near Rockhampton, Queensland, Australia
    5,297
    388
    1831
    Post
    You mean a 3304, there never was a 3404..
