The key with box tools (which took me a long
time to figure out) is that on most of them,
the tool is cutting so the sides doing the
cutting are not the usual ones.
If you have a regular 1/4 inch tool in the
thing, the correct grind is basically one
hit on the wheel, against the end of the
tool, to form the back rake and side rake
for the tool. The clearance front clearance
angle is pretty much set by the tool holder.
To put this another way, the *end* of the
tool for these things is doing what the top
surface of a regular lathe tool does.
When you set them up, the spindle turns the
regular forward direction. You have one roller
on top, to keep the work from climbing up,
and one at the back to keep it from springing
away from the tool. One the box tools I own
(boyar schultz) I adjust the tool on center
by rocker it on the teeny rocker using the
two clamping screws. The diameter is set
by moving the tool fowards or back using the
micrometer adjustment screw. You take a rough
cut, measure, and tweak the screw till it's
right.
Don't try to set these up with the spindle
running backwards, and don't try to bring the
tool on center with that micrometer screw.
On the ones I have, you can set the tool leading
or lagging the rollers - I seem to find that
the tool leading works pretty well, which
means the finished diameter has to pick up the
rollers. I'm just a novice at this so listen
to what the old hands have to say, and do that.
But the things that got me into the most trouble
were:
1) spindle should be turning forwards
2) tool set on center with rocker and clamp screws
3) tool can be made to work with one single
grind on its end
Good luck - Jim
