muleworks
Cast Iron
- Jun 18, 2005
- Reform Alabama
I need a 50 ton porta-power. I have looked in MSC, Hydraulic Books, even the Thomas Register. I haven't found nothing but these little toy porta power fender bender deals. What I'm looking for is a industrial model. The cyclinder weighs about 80 lbs, has a 2" hole through the center so all thread rod can be put through and washers with nuts applied so you can pull bushings in and out of heavy equipment. Its also for pulling big CATERPILLAR pins in. They are threaded in the center so a piece of 1" all thread will thread in there and pull them in. The one's I've seen have a remote switch so you can use it under the equipment or off to the side. And the cyclinder is double acting meaning its powered in both directions.
ANY help would be very appreciated!!
Chris
Chris
