Results 1 to 8 of 8
    ipstoneys is offline Junior Member
    Dec 2005
    pa
    Post
    Can anyone help with telling me the weight of a empty 12 oz and the weight of a empty 16 oz aluminum can?TIA Chris
    bcstractor's Avatar
    bcstractor is offline Stainless
    Apr 2004
    Monument CO USA
    1,904
    Post
    It depends on the can. Diet Coke cans are quite a bit thinner than the rest.
    What sort of 16oz were you thinking of - some of the Australian ones are quite heavy.
    Chris P
    lathefan's Avatar
    lathefan is offline Titanium
    Nov 2003
    Colorado
    2,119
    Post
    You need to find someone who reloads ammunition and has a loading scale (you'll need to convert from grains to whatever unit of measure you're looking for).
    Dec 2005
    pa
    Post
    Well to be honest its a coca cola "and or coca cola products"12 oz. can.The 16 oz. is a stoneys beer can.Math wise, I think if you take the dia. the length.The thickness?? Cant you come up with a weight?Or if I cheat and set them on a digital weight scale????Thanks Chris
    WJHartson is offline Senior Member
    Feb 2003
    Pass Christian, MS, USA
    490
    Post
    Aluminum cans are made using the draw and iron method. First a disc is punched out of a sheet. Today they are getting either 12 or 14 discs out of the width of the sheet. Their is a very slight variation in the thickness of the sheet from center to edge. This is needed for tracking through the rolling mill for stearing. The discs are then punched into cups with the bottom configuration. The cups then are places in a die and a ring is pulled up the outside to form the sides of the can. This reduces the thickness of the wall with the bottom of the can remaining the original thickness. The can is then trimmed for the proper height and the top flange/neck is formed. Each of the can companies have their own design for the cans based on strength needed for the product that will be in the can. All of the cans have a coating on the inside so that the products taste is not affected by the aluminum. The label on the can is an ink. The lids also have some difference in design.
    Depending on how accurate you have to be on weight will determine how you go about finding the weight of a specific can. Weighing it on a scale would be the most accurate for a particular can.
    Can thickness and design has changed over time so has the weight of the cans.
    Hope this helps.
    Joe
    sandman2234 is offline Titanium
    Jan 2003
    Jacksonville, Florida, USA
    2,316
    Post
    Joe,
    Fine job of explaining! Sounds like you might have been in a can plant before.
    David from jax
    Feb 2003
    490
    Post
    Sandman, worked in the aluminum industry for 30+ years. All aspect of the industry including rolling mill which made can stock. Got involved with all of the problems that the can plants with gage, earing, tearoffs etc. Roll grind and finish also plays a big roll in deep drawing aluminum.
    Did you work in one of the can plants in Jacksonville?
    Joe
    RDL
    RDL is offline Hot Rolled
    Jun 2005
    Edmonton,Alberta,
    984
    Post
    An accurate scale is your best option. There are several thicknesses plus there will be tapered areas because the aluminum is drawn. Even if you can remember how to do integral calculations it probably will not be as accurate as a good scale. Weigh 10 or more at a time to get a more accurate reading.
    Raymond
