oil for harig 612 surface grinder
Results 1 to 8 of 8
    May 2004
    minnesota
    154
    112
    Post
    what kind/weight oil is supposed to go in the oil tank of a harig 612 surface grinder, older machine say 70's ? light like spindel oil, for number 2 way oil? what do you use?
    thanks chet
    Feb 2004
    Macon, MO USA
    282
    5
    Post
    Chet, the tag on the back of my 612 recommends a 150-225 SUS @100*F way oil. The Harrig manual very strongly suggests that you use their way oil in order to prolong the pump and the ways. I just use Harrig Way Lube #16211245 as it isn't all that much more expensive. Replacing the pump is expensive. If you call Harrig in Elgin Ill., ask for Jim Seyller. He is very knowlegable and helpful. He can tell you anything you need to know about your machine and get your oil ordered for you. 150-225 SUS would be comparable to Vactra 1. Harrig can be reached at 1-847-695-1000. Doc
    May 2003
    4,264
    115
    Post
    I would highly recomend the Harig way oil, it is slicker but spendy.
    Jan 2003
    Genoa, Illinois
    1,470
    11
    257
    Post
    Chet:
    I called Harig about a year ago concerning a substitute way oil in their machines. They claim there is no substitute for their oil. Regular way oil will gel up and not pump through the system.
    I have ran Harig surface grinders for 25 years at work and now have my own 6x12 in my garage. They are built 20 miles from home in Elgin Illinois. In fact Jim Seyller and I know one another from High School.
    Check the oil pumping system often.
    Use only Harig way oil at a cost of $40/gal
    Jim
    May 2004
    minnesota
    154
    112
    Post
    thanks guys
    chet [img]smile.gif[/img]
    May 2004
    minnesota
    154
    112
    Post
    do you guys do any od grinding on your grinders?
    looks like the one i have locks on the cross only (y axis not the x). is this the case? i dont see a another lock.
    Jan 2001
    Minnesota
    2,160
    62
    1204
    Post
    Adjust both the table stops tight against the pin to lock the X.
    May 2004
    minnesota
    154
    112
    Post
    yea, great that will work. thanks [img]smile.gif[/img]
    chet
