OT - Cell phone charger tripping GFCI
Results 1 to 7 of 7
    Feb 2004
    Attleboro, MA, USA
    785
    7
    Post
    Has anyone else had this happen? My wife and I have always plugged our cell phones into kitchen outlets to charge since it is conveninet to leave the phones on the counter while charging. The last 2 sets of phones we had never did this, but the chargers that came with our current phones will often trip the GFCI at some point during charging. It has also happened if we turn the phone on or off while charging. It has done this on 2 different GFCI circuits, so I don't think it's a faulty GFCI, but who knows.
    Just wondering if I'm the only one...
    John
    Nov 2005
    Maryland
    8,502
    741
    1055
    Post
    Hi John,
    GFCIs are very sensitive devices. They work by comparing the current flowing in the two lines. If the values are different, the GFCI trips. It's possible that your charger generates noise of a type which unbalances the lines briefly, but long enough to trip the GFCI. Just speculation.
    Modern switching power supplies (ala your chargers) are very complex devices. GFCIs were designed to deal with simple things like lights and hand drills.
    Oct 2003
    East Peoria, IL, USA
    5,226
    288
    684
    Post
    gfci senses a different current in the two legs and figures there must be a short to ground and trips.
    maybe the cell phones, while searching for a tower are actually pulling just enough power (and dumping it into the air) that it trips the gfci same as if it was dumping it into say the kitchen sink if you wer to knock it into the dishwater?
    neat.
    Feb 2004
    Attleboro, MA, USA
    785
    7
    Post
    Believe me, I know how sensitive GFCIs can be. As VFDs become more and more common in residential applications, the number of tech support calls I get concerning GFCIs tripping is on the rise. I just find it odd that a device that is meant to be plugged into a residential outlet would trip it.
    I know my treadmill specifically said not to use a GFCI, and sure enough it tripped it when I tried.
    I would just feel a little better if someone else has experienced the same thing. Maybe I'll replace the GFCIs anyway and see if that changes anything.
    maybe the cell phones, while searching for a tower...
    It has also happened with the phone off.
    John
    Sep 2004
    Calgary, AB
    27
    Post
    I have a switching power supply for my laptop that always trips the GFI breaker. There must be something about the high frequency noise from switching supplies that ground fault detectors don't like.
    Allan
    Jan 2003
    Central Kali.
    1,981
    12
    Post
    You might try it with an adapter so the ground pin is not connected.
    Feb 2005
    Birmingham, AL
    4,023
    12
    40
    Post
    Interestingly that doesnt seem to matter. I suspect phone can talk all by itself if signal is present and battery has power. When my mobile phone transmits I can hear digital tones on my nearby corded phone during a conversation. Just a short little "here I am" most of the time it seems. That way they can generally track anybody they want just by their mobile phone.
