bigais
Stainless
- Sep 29, 2003
- Etters Pa USA
In my travels I came upon a neatly constructed building. This fellow poured a concrete slab with a flat piece of steel going all the way around the perimeter with bolts welded in it facing up and rebar pointing down.The upward facing bolts were on a pattern to accept the footplate of a standard 3x3-48" rack upright spaced 48" apart on the perimeter of the slab. He tied it together with cable and drawbolts x'd from corner to corner.He had a plate welded to the top to accept a wooden header to set the trusses on. The whole thing was sheeted and siding installed and insulated and made a sturdy job. He only paid $20.00 ea. for the rack as they had surface rust and would not be desirable for inside warehouse use but worked fine for his needs and allowed hin to cut at his desired height.Over the doors he used rack beams for support between the uprights and covered them with wood and vinyl. It turned out real nice.
