johnnydmetal
Cast Iron
- May 15, 2003
- Mine Hill,NJ,USA
I just stroked my 360 FE to 401.1 cu. basically specs out between a 407 and a 410. This will be the core for my 68 Ford F100 2wd.
I am doing a ground up rebuild of the entire truck from electrolysis on the full frame, new disc brake system (all round. No more Drums), Air ride self leveling 4 full bags, custom Cab mods, new rubber, full cut and weld of all cancer (rust), and all the bells and whistles.
So after all the overhaul and custom work that I’ve planed for the chassis I would like to dress the engine appropriately. I’m installing a 4 core radiator with dual electric fans so the pump mounted fan goes bye bye. I would like to go with billet pulleys and possibly a single serpentine belt, but I have not been able to find suitable parts for the 360-390 as small blocks sets seem to be all that’s out there. I plan to add an AC compressor as well as power steering and from what I’ve seen most are set up with a two belt system. This would be fine but as I said I have had trouble locating the sets.
I do have a SB H10” lathe but without some pattern info producing my own could turn into a bit of a headache in several ways.
Making my own pulleys seams like an awesome addition to a full custom truck project and an awesome way to break in my recently assembled h10. She still needs the right gearbox but the drive table, ways, carriage, and headstock all are clean and tight. Funny thing I have had a bit of trouble locating the correct gearbox and lead screw combination, as well as the correct banjo. So I have the ability to hand feed but the whole idea of the h10 is screw cutting ability. I’ll get there soon I just have to keep looking.
Does anybody have specs for producing engine pulleys or recommend a book for that?
If anybody knows of a reasonably priced supplier out there and if so do they have a web page I’d appreciate the information?
Thanks and happy Thanksgiving
John
By the way – Does anyone have a source for lacing staples? I have the crimping tool and 4 or 5 belts but I need to pick up some staples. A regular source would be best. Thanks.
John
