OT: How long does diesel fuel last??
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Aug 2004
    Northern Ontario, close to the polar bears (seriously)
    300
    Post
    Howdy:
    I just finished building a backup diesel genset for my house, and mentioned to a friend that it would be nice to have a decent supply of diesel fuel in case of a long power outage. He told me that the place he works at has two 45 gallon drums of #2 clear diesel that has been sitting outside for around 15 years, and they want to get rid of it before the drums start to leak.
    15 year old fuel would not be my first choice to run in my genset, but if this old stuff is still usable I would consider asking for it. I would expect to have to pump it through a strainer or filter of course.
    Anyone know if this fuel would still be any good? If not, how long can you store diesel before it goes bad?
    Michael
    Dec 2000
    Coastal Dogpatch, SC, USA
    50,700
    2435
    5274
    Post
    It should be ok but will likely need to be "polished" first. Polishing involves pumping the fuel thru special filters at high pressure and returning it to the tank and then back thru the filter system, back to the tank, and on and on until it's clean again. Diesel tends to have algae growth problems when it sits for over a year...but this is mostly confined to the bottom of the tank, but sometimes gets on the vertical walls as well.
    If you are near a marine area, there are usually professional fuel polish companies available for hire that deal with these issues on yachts all the time.
    Aug 2004
    300
    Post
    Thanks Don. How high is high? All I have kicking around is a 7 psi fuel pump.
    Dec 2000
    50,700
    2435
    5274
    Post
    Dunno...here's some good info on the subject
    www.trawlerworld.com/features_06.htm
    I've seen portable hydraulic and coolant filtration systems at machine tool auctions that seemed to be about the same idea.
    Jan 2003
    Central Kali.
    1,981
    12
    Post
    One place I worked at had several sites with diesel generators for backup. Once a year we sent a fuel sample to a lab. They sent back a report on how many gallons of some additive to dump in the tank. I forgot what it was but the diesel was probably over 20 years old in most cases. The lab never said the fuel was bad, replace it.
    dloc Guest
    Post
    If I remember right, ASTM specs for diesel fuel stability is 1 year. The difference grades of diesel are for fractions with different boiling points. The specific chemical analysis within a grade is dependent upon the source of the crude oil being distilled. There is a considerable difference in BTU's per gallon from different refineries. There is also a difference in stability between refineries but the biggest difference lies in the additives that different retail brands add to the product coming out of the transport pipeline.
    You could have it tested but start by looking at it (is it clear or cloudy) and smelling it (rotten eggs, etc. is bad). Don is right, filtering can do wonders but there are exceptions. In that case, dilution is the short-term solution.
    Dec 2005
    Orlando, FL
    553
    Post
    There are preservatives for diesel just like for gasoline. Using one will prevent certain bacteria and algae from colonizing the fuel which is the number one problem with long term storage of parrafinic fuels like diesel. Evaporation of volatiles is not a big problem for diesel like it is for gasoline. Kerosene (diesel#1) generally keeps a little better than diesel oil #2, which is what is available at most pumps. Jet A, AKA aviation grade kerosene, keeps very well. Diesels don't seem to know the difference between these fuels, running quite hapily on any of them, especially stationary engines like on a genset. With some injection pumps, accelerated wear can result from long term use of Jet A since it's a little less oily than diesel #2 and for some injection pumps the only lubricant is the fuel. If you're worried about that just mix a little motor oil with the Jet A. The suggested ratio is 1-2 qts per 55 gal drum Jet A.
    Jimbo
    Dec 2000
    50,700
    2435
    5274
    Post
    jimbo1490, I see you didn't read the link I supplied. Re additives-
    The Pour-in Solution ?
    It is very popular today to think that something you can pour into a fuel tank will take care of your fuel problems. There is a large body of experience, including my own, to indicate that any pour-in solution only treats some of the symptoms, but that's not the real problem with this procedure The problem is that while the immediate symptoms may vanish, this cure begins to create its own set of problems. If you kill the bugs, their dead bodies will cause problems sometime in the future * they just become part of the jelly that wants to collect at the bottom of the tank, and we know where that leads. If you emulsify the water in the tank, it still goes through your injection pump and injectors, and will lead to a whole new set of problems.
    May 2003
    1,124
    Post
    Interesting subject...I have a diesel tractor that is very seldom used...so how long can one let the fuel set before problems occur?
    Does one have to replace it and if so, when?
    TMT
    Dec 2005
    Orlando, FL
    553
    Post
    Definitely the key is PREVENTING the bugs from colonizing as I stated. The Additive I refer to is Biobor which is NOT an emulsifier. I never liked the idea of emulsifying water into diesel oil preferring a good Racor water seperator instead. I've owned three diesel P/U trucks over the years and installed a seperator on each of them. Diesel injectors and pumps are very close tolerance parts and just dont tolerate water or grit. I have a chance to grab 5 drums of Jet A 'de-fuel' right now but after thinking about filtering and seperting water I thought it better to just let it go to the fuel dump [img]tongue.gif[/img]
    Jimbo
  11. #11
    Jan 2003
    Jacksonville, Florida, USA
    2,324
    10
    Post
    We pumped 200 gallons from a truck wrecked 3 years previous, into my truck. After changing the filters 3 times, we dumped the entire tank and started over. Wish I had known then, what I know now.
    David from jax
  12. #12
    Mar 2006
    Oxford, MD
    647
    12
    54
    Post
    From many hours working with marine diesels, I'd suggest you obtain a fuel sample and provided you can see through it, it'll probably be good to use. If it looks murky, avoid it because it was probably stored in a moisture-rich environment. Under these conditions, "algae" (microbes) will form at the fuel-water interface and create copious black sludge that is capable of blocking filters very quickly.
    Additives can help clean up dirty fuel tanks and their contents, but are not ideal, especially if you've currently got a clean tank.
    Professional fuel polishing services can be very expensive (sometimes more than the cost of new fuel), so unless you happen to own a bunch of dirty fuel and would otherwise have to pay to dispose of it, you probably don't want to go that route either.
    In short, obtain clean fuel and keep it clean by keeping it dry. Tank vents can be a significant source of moisture intrusion...
    Graham
  13. #13
    Feb 2004
    Billings, MT, US
    152
    Post
    I would not run a generator or any other engine on this stuff, it just isn't worth it for 90 gallons. Lots of guys around here have heaters that will burn waste oil or just about anything else liquid. They will usually pay 50-75 cents per gallon for this type of stuff. Maybe more now that fuel prices are higher. That is the perfect use for this type of older fuel. I would sell this stuff and use the money to buy some good fuel. For the small value of the fuel it is not worth the engine risk. A full set of lab tests to recertify the fuel would run at least a couple hundred dollars, so that is not really an option. If you absolutely have to use it, I agree, check to see if it is clear and if it has any water in it, filter it, and then dilute it at least 50/50 with brand new diesel 2. that will help it run through the system. Frankly, it just isn't worth it for 90 gallons. If I was going to store diesel for a generator, I would rotate it annually by using it up and getting new fuel.
  14. #14
    Dec 2004
    Little Rock, Arkansaw
    1,237
    Post
    Blend it with fresh fuel. Make sure you have a good filter on your tank. That should be done with any fuel, specially diesel.
    We use a whole lot of it on the farm.
    Grits
  15. #15
    May 2003
    Central Coast of California
    166
    Post
    The fire department at Burt Rutan's Mojave Airport would not allow facility expansion until the water storage for fire supression was enlarged. Every nut and bolt had to be approved by UL or others, to meet insurance requirements and guaranteeing a reliable pressure/volume system.
    Two LP gas fueled IC engines/fire pump combos were installed. NO diesel and NO gasoline.
    J
  16. #16
    Jan 2006
    Isle of Man
    122
    Post
    Hi Guys, interested to see how stable diesel is, especially considering the problems I've encountered with petrol going off.
    Apologies, butI must be picky here though (Microbiologist!), there is likely to be NO algal contamination of the fuel, since Algae require Light for their growth. This is the same for the cyanobacteria (AKA blue-green algae), and in an enclosed steel fuel storage drum there is no light.
    Bacteria are a different matter,and if there is water in the fuel, they will colonise the interface between the drum and the water/fuel. There are several species of bacteria and fungi which have colonised this niche, and cause storage problems worldwide.
    For nowt, I'd get the oil and burn it to heat the garage/workshop, got to be cheaper than what I pay for the electricity.
  17. #17
    Dec 2004
    1,237
    Post
    The last post is good. Keep light, water, and air away out of the fuel and it will last longer. Something I did not mention on my last post which is in agreement with DC, don't save it for an emergency situation. I would not like to tell my wife in a cold dark house the generator is not running because I put fifteen year old free fuel in it. I would get very lonesome if that happened to me. If you do try to use it and it does not run when it is cold and dark, just say bad fuel and act like you are mad at the distributor. Don't go into detail.
    You can buy abdicatives that will inhibit the growth of bacteria. I would highly recommend rotating the fuel every year. We keep fuel through the winter on irrigation units but that is about it. Condensation in the tanks if they do not have much in them is the biggest problem.
    Grits
  18. #18
    Jul 2005
    Wensleydale, UK
    1,195
    9
    51
    Post
    Very intersting!, my previous employer had 100+ radio sites with a 5kW diesel generator backup for power. They were run for 1/2 hour once a week for testing so the tank was only re-filled every 3/4 years on average. Never heard of a problem other then water ingress in the fuel.
    Frank
  19. #19
    Jun 2006
    manager
    9
    Post
    Ladies and Gentlemen:
    How are you today?
    Chinahanji Parts Plant-We are a Professional manufacturer of Diesel Fuel Injection Parts,Such as Nozzle, Plunger & Barrel, and Delivery Valve and so on. All the products are gone through serious and strict quality control process, and have already exported to various countries of all over the world Our excellent Quality has been performance in various kind of reputation brand ---BOSCH, ZEXEL, DENSO, Delphi and so on. The price is good, the delivery is quick, the service is good, good service or help is free. We are committed to providing the highest quality parts at the lowest price.
    Below are the unit quotations of some parts as your reference:
    Rotor Head 3-6cyl:USD25-40/pc
    Element & plunger A, AD, P, B USD3-5pc
    Element & plunger MW.P7100, Ep9 USDS8-20/pc
    Pencil nozzle 27333, 8N7005 USD12-40/pc
    Nozzle (all types) USD3-5/pc
    Delivery valve USD1.5-3/pc
    Also, we are a member of "ADS ", which is the worldwide diesel industry’s leading Trade association, dedicated to the highest level of service on Diesel Fuel Injection. We sell and
    service some of the finest, mostrecognized
    brands in the world. If you have any questions,
    comments, or concerns regarding us, we will be more than happy to hear from you.
    We wish you the best of luck in business and life! Thank you!!
    SINCERELY
    Visit our website: http://www.chinahanji.com & http://www.vepump.cn
    Contact name :chen zhong
    addressubin Industrial Estate,Hanjiang District,Putian,Fujian Province China
    Email:support(a)vepump.com
    Tel:+86-0594-3603380
    Fax:+86-0594-3600560
    diesel fuel injection part, diesel element,diesel plunger, diesel barrel, caterpillar, bosch, denso, zexel, STANADYNE, YANMAR, AMBAC INTERNATIONAL, LUCAS-CAV, hydraulic head, cylinder/ distributor head, head rotor, military truck part, hd90100, nsn 2910008287176, m35 series, m series, caterpillar diesel, pencile nozzle, 8N7005, ZEXEL, BOSCH, DENSO, DELPHI, military part, military vehicle engine part, armoured vehicle part, diesel part, diesle injector, diesel injection, ZEXEL, BOSCH, DENSO, DELPHI, LUCAS-CAV, STANADYNE, AMBAC INTERNATIONAL, CAT, MTU, KOMATSU, TOYOTA, SUZUKI, NISSAN, MAZDA, HONDA, HINO, cylinder head,hydraulic head, head rotor, nsn2910008287176, hd90100, nsn 3040007223536, hd8821,military vehicle part, car part, cummins, komatsu, cat, caterpillar, diesel injector, caterpillar diesel, pencile nozzle, cylinder/ distributor head, ve-pump
  20. #20
    Nov 2005
    ridgecrest calif
    691
    22
    Post
    Working in the mining trade and as a generator tech i have had to clean up diesel gen sets and air compressors that have set for years. The problems with old diesel are water and algae. It helps if you can treat the fuel with algaecide and rig a electric vent valve on the tank to seal the tank and keep the water out. A expansion tank can be piped to the fuel tank to take care of the changes in temp. the coast guard uses this type system with a nitrogen gas cap system on deep water lighted buoys. Get a good filter/seperater to keep the fuel going to the gen set clean and keep the tank as full as possible.the faster the fuel will go bad. You can blame the navy for the algae. They started useing it about 25 years ago to clean up fuel spills and somehow it got into the distribution system. And now no one can stop it. Also the algae will collect the red dye in off road diesel and then you can filter it out. if you see what looks like clups of red jello in a fuel sample that is the live algae. and you need to treat your fuel. And the algae WILL grow in the dark just slower.
