Xtrucker_99
Cast Iron
- Dec 13, 2003
- milroy in.
hi guys,
i bought a used speedmaster 3 1/2 x 10" radial arm drill press. the fluids were all drained. i put hydraulic oil (iso 32) in the head so i could run it and check the feeds & speeds. after fixing the wiring and running it everthing works but its leaking out the spindle and the levers. is this just the wrong oil or will i need to put in new seals?
thank you
dt
thank you
dt
