OT - Old Sears Floor Jack Repair?
Results 1 to 7 of 7
    Jul 2004
    Houston, TX USA
    27,084
    Post
    Have one of the old 1.5 ton heavy ones built in Japan from flame cut plate instead of stamped tin.
    Sears does not recognise the 328.12001 Model number.
    Need a seal kit for cylinder.
    I did it in trying to lift the barn to replace the rotted sills
    John
    Nov 2005
    "The Golden Isle Of ",Georgia, US of A
    325
    Post
    take the unit to your local hydraulic repair shop.
    he prolly won't have the OEM but i bet he'll have a FIX for it.
    Dec 2002
    Marshall, Tx USA
    251
    Post
    Hi johnoder,
    I got a cup and some packing from a supplier here in Longview that is call Crown Supply. They have lots of o-rings, packing material, and cups made out of several different materials. Leather, rubber, plastic, nylon, etc. You will have to do the work.
    Or as the other poster commented, take it to a jack re builder.
    I think I repaired my 2-ton floor jack the last time for around $10.00.
    Apr 2005
    Benton, IL USA
    4,567
    7
    43
    Post
    http://www.southerntoolhydraulic.com...tml?check=true About the best in the business for identifying older cylinders & supplying replacement parts.
    http://www.baumhydraulics.com/ Not as good on I.D., but stock lots of parts.
    Hydraulic Equipment Co., 515 S Broadway Ave, Oklahoma City, OK (405) 235-3310. Jim (the owner) and Ricky (Manager) are really sharp.
    Nov 2004
    chicago
    252
    Post
    I have a 328.12002 (also 1.5 ton). Has to be at least 25 yrs old. Don't know what, if any differences between the two. I have the original owners manual and it gives a number for the power unit, part# 1511. It doesn't break down the unit any further than that.
    Sep 2004
    292
    Post
    I've got one of those old 1.5 ton Sears jacks also that was made before the whole world started going to piss.
    When mine stop pumping a few years ago it was just a standard o-ring in the pump assembly that needed to be replaced.
    Good luck, those are definitely worth fixing.
    Paul T.
    Jul 2004
    Houston, TX USA
    27,084
    Post
    Thanks for the input men. This thing still has its neat green paint. Date code ends with 069.
    John
