Quote:
Originally Posted by 1982shawn
Does anyone know how thick a layer of powder coating is? I need to know to allo clearance for a bearing carrier.
Shawn
The p-coat application, especially in holes, counterbores, will vary as well.
On critical masking/plugging issues--
I discuss this, in person, with the part in my hand, with the powdercoat foreman.
For close fit items--I have the surfaces masked, plugged or capped. Hi-temp, silicone mask tape, plugs, etc.McMaster-Carr has a sampling of hi-temp plugs and tapes.
Removing powder coat is a bear. I do that too--by burnoff, but never on finished parts. Only for prep and re-work.
Since the powder is applied electrostatically--the parts are hung and grounded thru hangers. This means that one or more holes in your part, will have little portions, not powder coated, since they were the ground area to the hanging hooks. These areas are touched up with enamel paint afterwards.
Additionally, on 'fussy parts'---I make a temporary, hanger--screwed into the part or thru bolted, to save hassle for the powder coater.
