Procut mill/drill?
Results 1 to 17 of 17
    Jul 2003
    38
    Post
    My local store has a Pro Cut (Rong Fu RL80RF311) Mill/Drill clone at a good price. Is anyone familiar with this brand name? What do you think of it?
    Dec 2000
    Coastal Dogpatch, SC, USA
    50,737
    2454
    5284
    Post
    That sort of machine is best discussed on a home shop machinist forum such as
    http://bbs.homeshopmachinist.net
    Jan 2007
    Newark, DE
    722
    8
    Post
    What I never understood is why someone would want to advertise the "drill" part on one of those things. Does that really need to be advertised? Do they think a mill can't drill? I guess I've been wrong, having put drills in milling machines all this time.
    Dec 2000
    50,737
    2454
    5284
    Post
    TD, not all mills have moving quills. In fact in the old days, most didn't. For that matter these should be called Drill/Mills, since they are better at drilling than they are at milling.
    Nov 2004
    Birmingham, AL
    13,055
    6176
    2438
    Post
    By calling it a "mill/drill" they make it easier to identify as a total POS. Truth is, it is a sorry excuse for a mill and the extremely limited space under the spindle makes it a useless drill.
    Apr 2005
    Benton, IL USA
    4,567
    7
    44
    Post
    Never heard of that one. The Rong Fu or Enco brands are always on sale, look here.
    I've drilled thousands of holes with my Enco M/D, and it's paid for itself many times over. Plus it does a nice job with solid carbide end mills up to 1", much better than the clapped out Bridgeport at work.
    Mill/Drills often show up in the For Sale section of the forum, usually in the $500 range. I'd be hesitant about the Pro Cut, only because it's an unknown.
    Barry Milton
    Aug 2004
    USA, Midwest
    613
    46
    Post
    I started with a mill/drill and have since added a CNC mill. Although the CNC mill has handwheels for manual operation, it lacks a manual quill. The mill drill is still a great tool for quick drilling/milling work. Mine has power downfeed which is also very nice for boring work. I thought about getting rid of it when I got my CNC mill but it's just bee too handy. It really is a very good drill press and an OK mill.
    Mar 2006
    UPPSALA SWEDEN
    175
    Post
    It is the other way around folks. It's a Mill/Drill
    that can't mill. They are good for keeping boats of up to 10' still while you're fishing.
    Andreas Proun owner of such POS
    Apr 2005
    Benton, IL USA
    4,567
    7
    44
    Post
    It's a Mill/Drill
    that can't mill.
    IMO, it does 90% of the work done on a Bpt at 1/4 the cost. I run a Bpt a work, the mill/drill at home, both are 2HP.
    Sure, the head on the Bpt will swing left/right, plus it will nod up/down. Features that I use perhaps once a year, if that. The Bpt table is larger in depth & length, which is usually an advantage.
    Will I ever buy a Bpt to replace the mill/drill, probably not. The two machines are far too similar, and both have somewhat limited capability. Would I buy a knee mill with a 40 Taper spindle, boxed ways & a larger spindle drive - in a heartbeat.
    Barry Milton
    Dec 2005
    Eaton Rapids Mi
    115
    Post
    Rod, this first mill is a round column mill/drill I bought new from Production Tools 4 years ago. It was a PITA to use if you ever had to raise the head and be back on zero after changing tools. I made a few of these quad wheel spacers and a few other things and ultimately sold it on Ebay after having it only 3 months. Lots of guys are doing nice work with them. I just didn't have the patience to fuss with realining the head.
    I bought this mill from Wholesale Tools in Detroit right after I sold the round column. I had this one about 3 years. Did lots of work with and and for the most part I enjoyed using it.
    Not to long ago I found this mill locally where I could run it and know what I was getting into. I sold the dovetail column on Ebay and bought this one. Granted I don't have near the machining time on this one that I did on the other two but here are my observations of have a heavier knee mill.
    It's easier to set parts up in (there is just more room).
    The cuts appear better on this one. I just took a .05 cut at 190 rpm with a 3" end mill on some 1018 cold rolled. The finish was great and didn't even sound like it was pounding anything to death. This end mill on either of the other machines would have had them beating them selfs up.
    In the end I would recommend going with at least a dovetail mill. Then just don't push the machine and you will be fine. Mine served me well.
    Good luck
    Bob
  11. #11
    Jul 2003
    38
    Post
    Thanks everyone. deere_x475guy how did you get your knee mill of the trailer when you moved it in?
  12. #12
    Dec 2005
    Eaton Rapids Mi
    115
    Post
    Rod, I had a friend come out with a huge tracked BobCat with forks. He unload this mill and set it close enough that a short roll on on 3, 4' long pieces of black pipe and it was in place where you see it. He also unloaded another basket case Chaviler Mill and the Harig 6 x 18 surface grinder for me.
  13. #13
    Oct 2006
    The Land Of Lincoln, where the air still smells fresh (SOME PLACES TOO FRESH)
    595
    5
    Post
    Yikes, this dang page is wider than my
    (_i_) <<<< click on that thingie to see what I mean
    deere_x475guy, how much did that Enco run you?
    looks nice, I've been eye'ing them for a while, is it accurate? rigid? and does it come with a DRO or do they offer a Retrofit like Prototrak, anilam or such???
    SteelCutter
  14. #14
    Dec 2005
    Eaton Rapids Mi
    115
    Post
    Steelcutter, I gave $500 for the mill and $300.00 for the Harig grinder and he gave me the basket case Chaviler 9x49 mill. The Mill was new in 1988 and the grinder was new in 88 also.
    The mill is very rigid and and it had a burnt up Fagor DRO on it. The scales are supposedly good but the power source is fried. I have a new 3 axis coming. As far as accuracy goes it has some wear as can be expected and I have learned how to compensate for it. All in all I am very happy with the upgrade.
  15. #15
    Oct 2006
    595
    5
    Post
    Homany dineros did the Enco run you? you know, dineros, pesos, dollars, yen, $$$$$, how many?????????
    SteelCutter
  16. #16
    Feb 2005
    Mich
    37
    Post
    we sell the pro-cut brand at our stores and for that type of machine it is as good as the other guy who make mill/drills
  17. #17
    May 2007
    Western Australia
    191
    Post
    From my research, all of about 2 weeks on this subject, I discovered far too many negative comments about the round column "mill/drill" in this size. I was looking to buy one, but found a second (third, fourth??) hand Parkson universal mill that weighs about 2 tons, which was about the same price as one of Chinese ones.
    I also met a guy that is a friend of my fathers, he has a mill exactly like the one shown in deere's post, but with a round column. They are all pretty much the same, bar weird names and such.
    After realising that the head can either move during machining, or is a pain to keep centered, I stayed right away from them. The second thing to do is to buy the same mill with a dovetail column - they are probably pretty good considering the price. If you have the room, buy an older horizontal mill, they are vastly more capable, albeit heavy and not so friendly on smaller parts. They are also cheap, because everyone seems to be buying BPT clones from china.
