What is the "swirl" pattern called?
Luke
Hot Rolled
Aug 23, 2003
Nevada,Iowa
I'm looking for the term used to describe a particular finish that is found primarily on industrial & mil grade electronic enclosures (sheet aluminum). I did a bit of searching and found this:
www.scaleaero.com/wendys_taube_9.htm, but no real info on how or technique. Thanks for the help.
Luke
Engine turned finish. Put a pencil in your drill press with some abrasive on the eraser and have at it. You'll need some good music and treats to help with the boredom ;)
Thank you. I had a little project this afternoon that I tried to achieve that look and got "ok" results. The 1/4" eraser would have been a bit much since the sheet was 12"x32". After a little trial and error I ended up making a 2" dia. felt fob and using a bit of light oil rotten stone (volcanic ash) for the abrasive. I got a nice swirl pattern, but a bit too shiney. Are there larger "commercial erasers" available.
Luke
You aint kidding there. Been there, and it sure was boring. Looks nice though. I know a guy that put an engine turned finish on all the trimwork of a firetruck with a cup wirebrush and drill. Sure looked nice when the light hit it. :D
Nick :cool:
Gunsmith used to do this on rifle bolt, gave it that extra nice look. Sometimes it was so easy to do, and the eraser on the pencil had found it's true calling.
Jerry
I'm thinkin gunsmiths call that jeweling. I have several jeweled bolts on my rifles. But I'm just learning the machining end of the business. Do machinist call it engine turned usually.
if you want larger "swirls" use a piece of wooden dowel or a broom stick turn the face square in a lathe and reduce one end to hold in a collet against a shoulder. take scotchbrite and cut a piece to attach to the mandrel with wire ties. apply some sulpher base cuttimg oil on your part and step off the pattern you want. just finished a dashboard for a '63 Falcon doing this. do all you engine turning from centerline then turn the part over to machine the portals for the instrumentation.
looked great...jim
For larger flat surfaces, I like the finish that a regular random orbital sander puts on raw metal.
I have made some things out of sheet and plate aluminum, and the finish looks nice on the raw metal. The circular patterns of the scratches made by the sandpaper show nicely depending on the angle of the lighting.
-Jon
a friend of mine worked for a company that made firetruck bodies, first day on the job being that he was the low guy on the totem pole he had to do that swirl pattern on the entire back panel of a firetruck, needless to say he didnt stay there long! but he told me what they used was the scotchbrite pads that twist onto the little arbor and are 3 inch dia. they put them in a right angle air drill and had at it, they said a die grinder was too high of rpm. i never tried it yet with the large scotchbrite but i did do a small tool with the wooden dowel in the mill trick once
Wow! thanks for all the info, guys! I guess I'll get some cratex and give that a try. My 7 year old son saw the plate this evening and thought it looked pretty cool and wants something like that too. I've also got an enormous bandsaw that could use some tricked out gaurds. Looks like me and the boy have some "shop time" comming up (when it's warmer).
Luke
