Forest pretty well covered everything even though it's more detail than necessary. Knowing how long the car(s) will be in storage and where makes a difference. Also what year cars, inside, outside, controled invironment?
DO NOT spray oil on the cars. It won't last and it will deteriorate rubber parts.
DO NOT cover with plastic or allow plastic to remain in contact with the paint. Cover with a cotton sheet(s). I think there's breathable plastic covers with cotton linning available.
DO NOT allow tape of any kind to remain in contact with the car. (Any part, including chrome)
Long term basics:
1. Remove all fuel (Tank, lines and carb).
2. Remove the plugs and sqirt oil in cylinders.
3. Crank to distribute oil, replace plugs.
4. Remove the battery and store away from the car.
5. Change ALL fluids (Oil, brake, antifreeze).
6. Wash and wax/seal the paint.
7. Treat the tires.
8. Jack the car up and remove weight from suspension and tires. Store on Jack Stands.
9. Keep the tires aired to full pressure.
10. Treat/coat all door and trunk weatherstrips with talcum powder.
11. Block or cover all the glass. Don't let the sun in.
12. Block or cover all plastic parts with cotton. (Tail lights, side lights, grills, etc.)
Eleven and twelve can be accomplished by one of the car covers mentioned above.
