SABS material spec
Results 1 to 4 of 4
    Mar 2007
    warren, mi
    1,161
    116
    298
    Default SABS material spec
    has anyone heard of a SABS material spec? south africa bureau of standards spec. the spec is the material for some kind of pin. as far as i can read the spec number is
    sabs 1431 gs 300wa
    any help would be greatly appreciated.
    Jul 2004
    Houston, TX USA
    27,198
    The have a web page - I suppose you could ask them:
    https://www.sabs.co.za/
    Oct 2005
    Durban South Africa
    165
    5
    Default Steel plate spec
    I have the steel mill spec sheet for this material. It is a plate and sheet spec and is what we would call mild steel ie. the basic grade of structural steel plate for general construction use.
    Tensile strength 450/620 Mpa. Yield strength +- 300 Mpa. If you need specific info (chemical comp etc) I can post it for you.
    Hope this helps.
    Tony in SA
    Jul 2004
    Houston, TX USA
    27,198
    Chapel has a nice conversion web page, like for Mpa to psi:
    http://www.chapelsteel.com/mpa-psi.html
    This SABS stuff is a little stronger than our ASTM A36 or ASTM A516 Gr 70
