I have some 4130 1.300" dia. tubing that has been heat treated to Rc41-44.
I have to drill/ream some .3125 +.001 -.000
holes thru the tubing.I purchased some 9/32 solid carbide drills, and some .3115 dia. solid carbise stubby reamers.
What rpm's and what feed rates do you all think I should run on the hardened tubing.
I have to drill 49 holes totally.
Each of the 7 tubes will have 7 holes.
I purchased 4 drills, and 3 reamers.
So I need to be conscience of tool life., and also hole dia. tolerance.
Doug.
Doug.
