Short MT centers?
Results 1 to 2 of 2
    Sep 2004
    Oakville, ONT, Canada
    337
    Post
    I'm outfitting the lathe I just bought with centers, it says in the manual that the headstock is MT 5. However I just bought a MT5 dead center for the headstock and it doesn't fit, almost like the center would fit if two inches were cut off the small end. Also the lathe came with a MT5 to MT3 adapter which would work as the overall length is shorter. I just figured that I might as well get a MT5 center and not even bother with the adapter.
    What should I do? Get a MT3 dead center and use it in the adapter or cut off the MT5 center I have (carefully) and use that, or is there some sort of MT5 short center I can buy?
    Jun 2001
    St Louis
    16,843
    1426
    2583
    Post
    You can always bag it and just make a short center to hold in the chuck. You turn it down a bit each time you use it to trim it perfectly true, and go.
    The chuck jaws make great dog drivers. Much better than trying to find a long-tail dog.
    Whoever suggested this to me gets a big "attaboy". It is much simpler than the long centers, and may be more accurate than the adapter and smaller center. I think that is what you are expected to do....many/most machines had a weird spindle taper and a special center sleeve, look at old pics. I know larger Logan have one of two proprietory spindle tapers, you have to use a sleeve.
    Since the center turns, the need for hardening is much less....tailstock one still must be hard.
