8ntsane
- Sep 7, 2004
- Barrie,Ontario, Canada
Hello all
I have a job that I need a finished size of 5/8
hole. I have never used a reamer, but I need this hole as accurate as possible. This job will be done on my mill BTW. I need to know if I could drill the part to 9/16 and then use the reamer to
take it to the finished size? Or should it be closer to the final size before useing the reamer?
I could bore the hole slightly under if I had to.
Then use the reamer to finish it to 5/8
Like I said, this is something I have never done, so maybe these seem like stupid questions , but hey, when ya don,t no the proper deal its better to ask.
Though it would make life easyer if I could drill it to 9/16 as mentioned, then take it out to 5/8 with the reamer,,,,,,,,but I,m really unsure about this,,,,,Guys I need you to set me straight on this. I don,t need to screw up the parts trying to do this the wrong way.
The parts are spindles off a RX7 , and the tapered
holes where the tie rods normally go in, need to be 5/8 to use a rod ends. This is why I need the hole as accurate as poss. The 5/8 bolt needs to fit with out being sloppy.
These spindles are a small fortune, and cannot be obtained at any old junk yard, so a screw-up would be very costly.
Thanks Paul
Thanks Paul
