Size markings on drill bits
Results 1 to 10 of 10
    Jul 2004
    Reddington, N.J., U.S.A.
    3,132
    219
    Post
    This question was first asked by my machinest neighbor 20 years ago, "Why do the manufacturers stamp the size on the very end of shank, instead of higher up near the flutes? If the drill grabs in the work, the marking can become un-readable."
    No answer could be found. So now it is my turn to ask the same question.
    Nov 2003
    Beaumont, TX, USA
    4,059
    126
    1061
    Post
    I have no real knowledge but if I could be permitted a guess, the cutting edges, flutes need to be hardened and it is hard to stamp on a hardened surface. The far end can be a lot softer and therefore easier to stamp. Of course, the softer area is also easier to bugger up if the drill slips in the chuck. SBT.
    Another possible reason is that the upset area around the stamping may cause the drill to be a bit off center in the chuck. This effect will be less if it is at the far end. Not by a lot, but by a little bit. And if you wanted to cut it off to eliminate this effect, it is better at the end.
    These reasons may not be relivant with modern day production methods but may just be carryovers from earlier days.
    Paul A.
    Apr 2005
    Benton, IL USA
    4,567
    7
    43
    Post
    Some manufacturers have replaced the stamping with etching or laser marking (Precision Twist http://www.precisiontwistdrill.com/ uses this type of marking)
    It would seem both these processes could be done easily near the flutes, but convention dictates that they be placed near the end.
    Mar 2004
    Lawn Guylin, Noo Yawk
    2,692
    20
    50
    Post
    Production methods? Nah.
    The bean counters stayed up late figuring that if you couldnt read the numbers anymore, you'd be too impatient to run over and get a mic. Therefore, toss that bad boy out, and go get a new one from the tool crib, store, industrial supplier etc.
    That is, until they ran into me, El Cheapo.
    Jan 2005
    Isle of Man, UK
    338
    11
    Post
    Try Dormer drills. Their marking on drills over 1/4 is in black on a ground silvery band usually clear of the jaws. The markings usually outlast the drill. Funnily enough, they don't do this on the fancy TiN coated ones, just the steam tempered.
    Jul 2004
    3,132
    219
    Post
    I'm not thrilled with the etched ones either. Difficult to see depending on the lighting and I've seen a lot of taps that somehow had the etched size completely wiped or rubbed off.
    Mar 2005
    Somerset, UK
    4,946
    406
    1477
    Post
    Here's a Dormer drill, as described by Greeno:-
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,039
    423
    1001
    Post
    Ahh that is to give you practice with the micrometer when you dump 114 of the 115pc on the floor!
    Dec 2000
    Bremerton WA USA
    10,617
    40
    3994
    Post
    Who cares if the size markings are spun off by the chuck? I got a micrometer eye. (I got a mike for a back-up)
    May 2004
    Vista, CA
    920
    202
    233
    Post
    I have a friend who has a micrometer nose ...Brown & Sharpe
    Jim
    www.pivotlok.com
