no.you wount be able to pry a tire over the rim.If you ever mounted tires you will understand.
J-King That is sort of what I was thinking. They are steel rims and I do trust my welding, the City of Memphis TN does to, but anyhow I am thinking that I would not be able to mount tires if I did it. What is the difference between todays rims and two piece rims that would be welded? Let me rephrase that, how can they stretch the tires over the solid piece rims? I have never mounted car rims with tires but I have mounted eighteen wheeler rims and I do know how hard it is.
Are you talking about steel rims? The old syle steel rims with an aluminum ceter, definatly not, they shouldn't be run in the first place. But if they are both steel and you trust your welding it shouldn't be an issue.
Toad jammer. Yea they are fully steel. Don't forget this is 1955 and a truck. The thing is one solid block of steel. No alumnium no plastic and no other fluffy ****.
They are the two piece rims that do not bolt together. It has got a solid center that comes up to the inside, still solid, than the outside has got the extra piece. I do not know what the style is called, other than knowing it is a two piece rim.
Newt
