DazedConfused
- Jan 5, 2006
- Isle of Man
Hi all, we have been making some gates for the back yard of a friends house out of square section steel tube, fabrication nearly finished, but now it needs painting. The gates are: 2 of 8'x4' and 1 of 7.5'x3' hinged on a frame of 2" square section steel, 8' tall and an 11' crossbar between posts.
We are scratching our heads over the best/easiest way of degreasing the steel before painting it. Acetone works well, but our supply is limited, and we are going through loads of rag/paper in the process.
We don't really want to go down the route of a wash off with water type degreaser, since that would mean then having to dry it thoroughly before painting to avoid the dreaded rust.
Any suggestions?
Chris.
Any suggestions?
Chris.
