Jason J
- Jun 6, 2005
- Towanda, Pa
About a year ago I bought a Wilton 7" x 13" horizontal bandsaw from Boeing Surplus for $200. It was kind of a strange deal because 1) it was so cheap, 2) it was missing the motor, motor mount, gimbal for the "top" wheel and cord, 3) it looked brand new.
The saw was <5 years old and lists for $3000. Wilton sold me the mount and gimbal for $109. Add a 1/2 hp motor and off we go.
Or not quite. This thing had a new 12 tooth blade on it, that wouldn't stay on for more than 20 seconds. It was flat across the back and sharp as a scalpal. I checked everything I could think of. Even replaced the driven wheel bushing. (Almost unbelievably Witon GAVE it to me. They said writing up the invoice would cost them more than the price of the bushing) The wheels were parallel in and the offset was nil. No adjustment would keep the blade from comingh off.
In desparation I got a new blade. 3/4" x 101"x .032" x 18T. (I already had the blade for another saw and had it shortened)
Viola, it stays on and the caw cuts. It will cut multiple slivers off of a hunk of 3/8" x 1 1/2" flat bar .025" thick with less than .002" variation from end to end!
It still sometimes slips the band off of the drive wheel, but this seems to be related to swarf packing up on the wheel AND vibration. I know that 18 teeth on 1 1/2" stock is not optimal, but no chance of getting an appropriate band thil Tuesday. The vibration does not seem to be coming from the area of the cut and varying the pressure of the cut seem not to affect anything. Either by increasing the feed, or putting more pressure on the back of the blade. It does not start immediately and it builds up gradually when it does. I suspect some kind of harmonic vibration. Because of lack of the factory step pulley on the motor I can't easily change blade speed. The bearings in the gearbox are tight, but there is some play in the drive wheel. I can move it 3/16" back and forth at the rim. Any Ideas? I think I will go remount the motor so I can try a higher speed. Clearly this was a problem child for Boeing and they finally gave up on it. The fact that they had the gimble off leads me to believe that it was taken out of service because of the band throwing problems.
