dwilliams1128
- Jul 27, 2004
Like I said I don't know how to cut threads yet, and maybe someone is in the process of sending me a copy of the manual for my lathe (9X20 lathe from WholeSale Tools Inc.) looks green. I can tell that somethings could have been made better, like on the tailstock there is a nut to clamp the stock down tight. But on some better lathes, there is a lever that you pull on to to clamp. And then about the tool post, it may be neat to have a quick change tool post, but I personally like the old fashoned ones with the half circle wedge that allows you to change the angle of attack of the tool you're using.
Well actually I have made threads before in a college class and made a nut to fit on it and it turned out pretty well (no pun intended) it's just that that lathe was bigger that this one and I forgot most of that by now. This site is helpful:
http://www.machinist.org/army_machinetool/ch7.htm
Over all I'm in the market for a used lathe that has been maintained well and has high tollerances, maybe around 2 to 4 horse power and dimensions a 12X40 engine lathe. These lathes tend to weigh around 1000 pounds and does anyone here know how to lift and move such a weight and get it into the lower floor of our basement?
Thank you.
David Williams
[email protected]
Bye
Thank you.
David Williams
[email protected]
Bye
