DJFAB
- Jan 4, 2008
- Lake Havasu, Az
Hi, I am new around here, and was hoping someone could help me out. I just aquired a TOS Trenchin SN40B-50B lathe and have some questions.
First, does anyone know what the -50B in the model number means?
Second, the manual that I got for it says that the lathe has foward and reverse, but mine seems to only run in foward-and the previous owner seemed to agree. The manual states that when the carriage lever is lifted up, the lathe will run foward-is this correct? The lathe was set up to run foward when the handle was pushed down, when you bring it back the clutch disengages, and if you lift it up it brakes(as in puts on the brakes).
I also notced that when the carrige handle is in the center locked position, the spindle will sometimes creep ever so slightly. Is the clutch and or brake worn or need adjustment? Was the previous owner and now me running the motor backwards, possibly causing the reverse to not function properly? Or do I have some strange lathe that doesn't have reverse?
Third, the lathe came with a large tool post that I can't seem to find anything about. It says- IMPERO M/T.16
It has a wedge-type quick release on the left, some other type of large quick release on the front and a large set-screw tool holder on the right. It has a couple of the wedge-type tool holders, but there seems to be parts missing-namely a way to set the tool holders height in the tool post.
Also I have no tool holder for the large front quick-release part.
Does anyone know anything about this toolpost or where I can find info about it?
Finally, the cross-slide in particular has a lot of sloop(you can grab the toolpost and move it back and forth app. 3/8 of an inch!). Is there an adjustment here or is the part that the leadscrew mates to just badly worn?
Thanks in advance for any help!
