EPAIII
- Nov 23, 2003
- Beaumont, TX, USA
I've been busy setting up a new shop and when I needed to brush some old paint off some steel plate I am using it took me over an hour to chamge my grinder to a wire wheel. It's an old grinder and several things came up including rust that I would not tolerate.
Anyway, I got to thinking. I only have one grinder and it has a coarse and fine wheel and then I went and bought a wire wheel. So changeing is a fact of use. But what if I mounted the wire wheel on a shaft extension. I could maching a 3 or 4 inch extension that attached via the spindle threads in place of one of the nuts and mount the wire wheel on that. Of course, I would have to extend the safety guard on that side.
But I wonder if this would be a good idea? Would it be safe? I do plan to bolt the grinder down with a loose fit on the screws so it will stay put but the rubber feet will still absorb much of the vibration. So it will not be in danger of coming off the stand. But are there any hidden dangers here?
On the new shop, I will post pictures when it is done.
Paul A.
Paul A.
