1/8 IPS Thread ???
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 63
    Jan 2008
    Wimberley, TX
    58
    Default 1/8 IPS Thread ???
    I searched but couldn't find anything. This must have come up before so forgive me. Lamp fixtures apparently use a straight pipe thread. I have looked in some of my machinist books (I'm an amateur homeshop guy) and can't find much. I want to drill and tap a hole for a lamp fixture nipple. The nipple is about 0.386 inches in diameter measuring across the tops of the threads.
    At my local Ace HW they show the designation for these nipples as 1/8 IPS. I believe the TPI is 27. Does the IPS stand for Iron Pipe Straight? I'm not familiar with pipe thread designations and can't figure out the 1/8 either. What on earth does this stand for?
    Do I want to buy a 1/8 NPS tap to tap this guy and therefore a tap drill "S"?
    Thanks in advance.
    -Art
    Aug 2002
    West Unity, Ohio
    23,117
    3425
    6399
    "I" = internal?
    P = pipe - but you prolly already got there eh?
    S = strait
    Your serious? You never used pipe fittings before? Pipe sizes are sized for the internal bore of the pipe, although in many of the smaller cases (especially 1/8") the bore is off nominal by quite a margin.
    W/O looking - yes - 1/8NPS is likely a letter S. (National Pipe Strait.)
    Also - 1/8 pipe is 27 TPI.
    While it is great that the local hdwr was able to help you out like this - you can save yourself many future haertaches (attacks?) by NOT buying hdwr quality cutting toys! And I kant stress this nearly enough when it comes to TAPS! They can be used succesfully in thread repair - but not for cutting new. (Your milage may vary.)
    Think Snow Eh!
    Ox
  3. Likes Metalcutter liked this post
    Jan 2008
    Wimberley, TX
    58
    Okay, but if 1/8 means 1/8" what does this refer to? Clearly the inside diameter of this is greater than 1/8". The S tap drill is 0.3480 inches, so I still don't understand the nomenclature of 1/8. Can you help or point me to an explanation?
    Oh, are you saying that the internal diameter of the male nipple is 1/8"??? That must be it. Am I right?
    -Art
    Feb 2006
    Indiana
    11,969
    446
    3145
    Quote Originally Posted by 11B4VLA View Post
    -Art
    I can point you at Google. Maybe "pipe size" will get you there.
    You already got the short, accurate explanation from Ox. If you want more, find it yourself. The Internet has all the answers if you will bother to search.
    Larry
  6. Likes digger doug, tdmidget liked this post
  7. #5
    Jan 2008
    Wimberley, TX
    58
    So Vance, why do you think google did not find IPS? Can you show me a query that will get that? A discussion on the Home Machinist board opined that it meant Iron Pipe Straight. Are your responses always so helpful or did you just pick me on a bad night?
    If it is so straightforward why don't you post a link to the definition of IPS?
    Thanks for very little other than entertainment.
    -Art
  8. #6
    Jun 2006
    Taylorsville Ky
    3,122
    26
    Art, I googled this for you http://www.sizes.com/materls/lampFit.htm and this http://en.wikipedia.org/wiki/Nominal_Pipe_Size and this http://chestofbooks.com/crafts/mecha...ron-Pipes.html
    All of the above were googled in 15 seconds and there's much much more.
  9. Likes digger doug, tdmidget liked this post
  10. #7
    Dec 2006
    Natick, MA
    75
    Default IPS Reference
    IPS = Iron Pipe Standard (not straight).
    A reference:
    http://www.keidel.com/mech/pvf/pipe-intro.htm
  11. #8
    Jan 2008
    Wimberley, TX
    58
    Default Good Links, Thanks
    Carl and Professor: Very interesting links. BTW, Professor, your link says that IPS is Iron Pipe Size not Iron Pipe Standard. So no wonder I couldn't measure anything that is 1/8" since the designation is historical and not current by measurement.
    So I think that I would be correct in using a non-tapered NPS 1/8-27 tap and an "S" drill as the tap drill. According to
    http://www.engineersedge.com/manufac...rill-chart.htm
    Okay, then, I think I get it.
    Many Thanks,
    -Art
  12. #9
    Apr 2005
    Southwest
    529
    7
    12
    11B4VLA,
    You've got it right on your tap and drill size, you could also use a 11/32 drill bit if you currently have one without buying a S drill if don't have one of these.
    I find google to less and less usable (for me), if you type in IPS, standard for IPS you get all kinds of crap before you find anything referring to Iron Pipe Size. After all there are a lot of acroymns that use IPS which none meaning Iron Pipe Size.
    Pipe sizes and their designations along with the proper taps can get confusing, since many of us and others have probably been around since the original IPS (Iron Pipe Size) standards. A lot of times we create our own standard based upon the new and the old ie., IPS (Iron Pipe Straight) vs the newer NPS as defined below.
    The problem with standards as once you get use to using it, then along comes some newer standard that tries to narrow the window by adding more standards. Pipe sizes are roughly denoted based on the ID, however it's the OD that remains the constant. Example: Schedule 10, 40, 80, 120 all have the same OD, while their wall thickness varies due to the pressure they can handle. 1/8 inch pipe is really the odd duck when it comes to pipe size since even at schedule 80 it's ID is almost a 1/4" in diameter. The number of threads is the easiest (for me) to tell the difference 1/8 and 1/4 inch pipe, 27 vs 18.
    Ok, so much for the hot air I am blowing today.
    American National Standard Pipe Threads
    NPT: National Pipe Taper Thread A sealant compound or Teflon tape must be used for a leak-free seal.
    FPT: female (internal) National Pipe Taper threads
    MPT: male (external) National Pipe Taper threads
    NPTF: Dryseal American National Standard Taper Pipe Thread No sealant is needed for a seal.
    NPS: American Standard Straight Pipe Thread Used for mechanical joining -- holding a fitting in place. An O-ring or a metal seal is required.
    NPSF
    : Dryseal American National Standard Straight Pipe Thread
    British Standard Pipe Thread
    BSPT: British Standard Pipe Taper threads
    BSPP: British Standard Pipe Parallel (straight) threads
  13. #10
    Feb 2006
    Indiana
    11,969
    446
    3145
    -Art
    Your question was, "Okay, but if 1/8 means 1/8" what does this refer to?...Can you help or point me to an explanation?"
    I thought you were intelligent or interested enough to follow my suggestion and Google "pipe size" in order to answer your question. Sorry I was wrong.
    I took the time to try it myself and found the first hit contained more than most people would want to know about pipe size:
    Larry
  14. #11
    Oct 2010
    New York
    56
    9
    Default Condescending reply, ignorance of the subject, and poor spelling!
    "I" = internal?
    S = strait
    Think Snow Eh!
    Ox
    People come to these forums looking for information, not criticism. It was pretty obvious the person you critiqued was talking about straight threaded lamp fittings, NOT the tapered pipe fittings commonly used to seal gases and liquids. Yet you proceeded to ridicule him for being ignorant of pipe threads!
    Your post is loaded with grammatical and spelling mistakes. I counted no less than 10 of them. Maybe you should learn to write before dispensing criticism.
  15. Likes aerodark liked this post
  16. #12
    Feb 2008
    Washington
    2,835
    Quote Originally Posted by Engineeringtech View Post
    Those mistakes are endearing................
  17. Likes Modelman liked this post
  18. #13
    Jul 2004
    Reddington, N.J., U.S.A.
    3,132
    219
    A lot a lazy f*cks come to this forum too. They have a question or problem and instead of attempting to search the answer out, they register here and expect the members to spoon feed them the information.
    As far as any spelling errors incurred by Ox, the knowledge and experience he brings, outweighs your good grammar and spelling. Not everybody has IeSpell (or similar) loaded on their PC.
  19. #14
    May 2010
    Denmark
    17,420
    3541
    10234
    Thanks in advance.
    -Art
    This'll surprise those that know me but I'm going to give a short civil answer
    The diameter on a pipe thread refers to the approximate hole diameter of the pipe. It's the hole diameter on a pipe that's important so that's the diameter that's used when specifying a pipe thread. The pipe OD will depend on the pipe wall thickness and must sometimes be turned to size.
    Gordon
  20. #15
    Mar 2005
    Kansas
    6,690
    355
    2878
    Talk about condescending and ignorance, you with your 6 posts come in here and rip up somebody with 13,000+ posts? I'm guessing from your screen name you spend all day pushing paper and are only critiqued on what clueless superior paper pushers can find as faults. Then there are people like OX that spend all day with their hands dirty actually doing stuff. They don't have the time or inclination to spell check or toe the current line on political correctness. Your type run to them when your ass is in a jam because you know they can bail you out, but you won't give them the time of day otherwise.
  21. #16
    Aug 2002
    West Unity, Ohio
    23,117
    3425
    6399
    Well now....
    FWIW - I saw this thread pop to the top and saw that I has replied to it once upon a time, so I checked it out to see...
    I read my reply and thought that sounded a bit harsh. Not sure why I did that. ???
    And then to find that the only reason that a 3 year old thread had surfaced was to bitch at me about it?
    EDIT:
    After re-reading my reply a cpl more times - trying to figger out why I werded it that way, I don't think I meant it in nearly a condecsending way as it appears. I think I must have been more in shock as to think that someone on a machine shop forum would not be familier with the 1/8" pipe designation?
    I don't know - just guessing as I didn't use any emoticons that day - I kant be sure anymore either.
    My speling and gramor aint neccessarilly dun in error BTW.
  22. #17
    Apr 2010
    IN, USA
    547
    9
    172
    Geesh. Are you really going to dig up a 3 year old thread to point that out? So, your contribution to a "machining" related forum is to point out spelling and grammatical errors? This isn't English class. And, I always found that OX's posts commonly have similar such errors, such as "skewl", "werk", etc., but I have always read them to be his personality. At least he threw in an extra tip, suggesting to not buy tools from a hardware store, especially taps. Years ago, in a pinch, I bought a 1/4" NPT tap from a hardware store and it was worthless, almost as if the sharps were broken.
    With groing use of the internet, I began to see how common it is to find mispellings and improper grammar. It doesn't mean I critisized anyone about it though. If you want to make a real gripe, complain about spell checkers, cell phones and texting, etc., as they are making younger generation dumb as hell on that subject. And I have seen stupid errors on formal documents, where they most of all should not be
  23. Likes F Spicker liked this post
  24. #18
    Mar 2009
    Brunswick Oh USA
    4,244
    4252
    2492
    Well now....
    Oh yeah, well I fer won am apauled at yer spelink!
  25. Likes James H Clark, metlmunchr, steve-l liked this post
  26. #19
    Jul 2004
    3,132
    219
    Maybe Engineeringtech is yet another alias of "He who shall not be named", Queens, NYC lawyer, here to: stir the pot; raise a stink; start a shit storm; etc.
  27. #20
    Aug 2002
    West Unity, Ohio
    23,117
    3425
    6399
    Quote Originally Posted by Gordon B. Clarke View Post
    Gordon
    Actually - for most common sizes and schedules, the OD's remain the same, and the ID's change with the wall thickness. But yes, the "sizes" are relative to the bore, although 1/8 pipe has always seemed to me to be far from 1/8" bore. (shrug)
    It seems that pipe starts to use OD size referance @ 14" for some reason tho. ???
    I am Ox and I approve this h'yah post!
